Question about Panasonic Microwave Ovens
Microwave runs for only a few seconds and then an error message of H98 is displayed and quits working Microwave only used for 6 months.
  • Panasonic Master
  • 9,098 Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Being 6 months old means it will be repaired free of charge.
Posted on Aug 03, 2008
Panasonic inverter 900w microwave fault code h97
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
Error code H98
Hello
Unplug the microwave and plug it back in after 30 seconds to make sure the message did not appear because of a simple glitch. If it does not come up again, use the microwave as normal.
The "H98" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and customer service to find the proper part for the microwave.
Your microwave comes with a warranty that will cover the inverter if the warranty is still valid. Call the number for the warranty department or bring the microwave, with receipt, back to the store you purchased it from. This will save you the hassle of replacing the par
Oct 04, 2011 | Panasonic NN-SD797S Microwave Oven
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
Panasonic Microwave
the error code H98 refers to the heating filament on the magnetron, unless you are confident I would not progress further
Feb 18, 2009 | Microwave Ovens
H98 error
Dec 31, 2008 | Panasonic NN-H965 Microwave Oven
We have a panasonic inverter microwave model SN977. It now will not heat and it has an error message H98. My operating manual doesn't have that message. What does it mean
Nov 01, 2008 | Panasonic Microwave Ovens
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Microwave Ovens
Microwave Ovens Logo
808 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
