Question about Toshiba 27AF45 27" TV
Hello, I have a Toshiba 27AF45C television. The problem I am having is that the image on the screen is shifted over to the left, cutting off the picture and not giving the full view. I was just wondering what might be causing this and how to fix it. Thank you
    Top Expert:
  • Toshiba Master
  • 75,581 Answers
Hello
Horizontal 'Shift' is the problem to your TV. There are so many causes to this fault. Must troubleshoot from horizontal output section to video IF section. The main board has the trouble. If you can get its mainboard as card basis at your town, it will be best to replace it as card basis.
This is the picture of the main baord.
Posted on Jan 05, 2012
2 Suggested Answers
  • 375 Answers
SOURCE: Distorted television image
bad caps in power supply and poss. pincushion section.
Posted on Mar 28, 2008
Image is cut off left and right sides On toshiba flatscreen ?
Whatever the source of your video is, it may not be formatted for widescreen. You can try changing the screen format with your remote control.
Apr 15, 2014 | Televison & Video
Cant print screen?
Use this method to print screen.
Press and hold down the Alt key and the press the PrtSc key, this places the screen image into the Clipboard. .
Open a blank Word document and then Click on Edit - Paste.
The image is then places onto this page, you can up the image by holding down the Shift key and then place the cursor on the bottom corner of the image, then press the left mouse button and drag it down to the right, release the mouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correct proportion.
You can now print this image document and or add text before printing.
Feb 17, 2013 | Toshiba Satellite A665-S6070 Notebook
The image on my Toshiba 24V4210U tv is cut off on the left and right sides. Also, the Info shows 480i whereas the input from the service provider is 780p.
If closed evenly with a shaded area on each side that is the 4x3 format, I can look but so can you: some of the sets (Toshiba) are only 4x3 and not full screen (16x9) and to boot only work with HD on one input.
480 I or not is not HD.
YOU Using a box of some sort here for this set?
Dec 05, 2012 | Toshiba 24v4210u Tv & Dvd Combo
Toshiba LCD TV: Double image (right side) on power on
HEllo,
Did you find a solution to your problem?
Thanks
May 21, 2010 | Toshiba Televison & Video
Toshiba-10 yrs old. screen goes to black with sound.
Hello, :)
There is a how, and a why, but first, let's start with the how. Portable TV's have LCD, (Liquid Crystal Display) Screens. But the Screen is merely a vivid illusion created by the rapidly moving electrons flowing through the crystals themselves causing color contrast ratios to shift so fast, hence creating the image.
And now the why: the TV uses a back illumination to light up behind the screen. That is why the screen goes black. Normally in LCD's, there are CCFL, (Cold Cathod Floruscent Lighting), these are tiny lamps that should be replace easily. google replacement model for your TV, and aslo type model # plus ccfl lamp. :)
Apr 02, 2010 | Televison & Video
My Toshiba 27A14 model TV has an extended Image
i have a toshiba model:27a14 i connect a dvd but i dont have the optionto put the tv on video.
Jan 02, 2010 | Toshiba Televison & Video
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Image Shifted to the Right...
did you go into the service mode, only a good technician should go into there
Jun 22, 2008 | Toshiba TZ50V51 50" Rear Projection...
IMAGE IS ZOOMED ON SCREEN
use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
Feb 24, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
Toshiba 27AF45 27" TV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
