Question about JVC Audio Players & Recorders
I have a JR-S501 receiver that cuts out on the sound. The turntable works OK when hooked to another amp. Thanks for the help
    Brigadier General:
  • 8,546 Answers
So are you saying you have a turntable-only issue with the JVC (guessing about the brand)?
Does the JR-S601 work OK otherwise?
Given its vintage there could be oxidized contacts throughout which would cause crackly sound or total silence.
If it's only an certain source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Have you looked in the manual?
Posted on Mar 23, 2011
Cannot hook up sound to surround sound , everything else works, cd player, radio, tapedeck. just the turntable does not work. any suggestions? deb
Hi, you need to connect the turntable to your amp via a phono input connection. If no phono input available then a pre amp needs to be used between turntable and amp to up the signal. Cheers John. Styluscity@gmail.com
Sep 28, 2011 | Technics SL-1200MK2 Turntable
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
Stanton Turntable Problem with receiver/audio
You need a turntable pre-amp, or a receiver with turntable inputs.. The turntable is functioning properly, until recently no turntable had this built-in. Search ebay for turntable pre-amp and you should be good.
Oct 04, 2009 | Audio Players & Recorders
Looking for jvc old receiver model jr-s501
Did you ever find a JVC JR-S501 receiver? I've got one, with a problem. It will play fine for, sometimes half an hour, or sometimes less, and then a loud "POP" sound in speakers. But then will play fine again. Blows fuses on speakers.
Jul 12, 2009 | JVC Audio Players & Recorders
I'm looking for an old stereo receiver model jr-s501 made in the late 70' can you help me find it thank you
Hi there,I have a jr-501 that is in beautiful cond and working perfectly.I have been using it to drive my maggie 2.5's and it does a great job.I paid 100 canadian for it and would like to get my money back out of it.
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Turntable problem
It could be a couple of different things.
Do you get any sound, even very faint, if volume is turned up all the way?
If so, you probably have the turntable connected to the wrong type of input or you have the wrong type of turntable for the type of input you have on the receiver.
Older turntables have a very, very low level of audio output which requires an input that has much more gain than the normal type of audio input on a receiver.
Many newer turntables and receivers has the same level phono inputs and outputs as the other inputs and outputs of the receiver like the CD or Tape I/O. When an older turntable with such a low level output is connected to this type of phono input the sound is so low you can only hear it very faintly with the volume all the way up.
If you have the proper type of turntable for the type of input on your receiver, then the problem is most likely in the turntable. To check if it is or not, disconnect the turntable from the receiver, and then connect an RCA cable to the receivers phono input with nothing connected to the other end. Then with the volume turned up just about 1/4 to 1/2 the way up, touch the ends of the male ends of the RCA cable that are not connected to anything with your finger lightly tapping it a few times. You should be able to hear the tapping sound real easy in the speakers. If you hear that noise you know that the receiver is OK. If you don't hear anything the receiver has a pre-amp problem or the receiver is not set to the proper function.
If you determain the receiver is working normal, you have a problem in the turntable. Most times it is the stylus or the wires connected to the cartridge which holds the stylus.
Another thing to check is that if your turntable has a ground wire coming off the back of it near the RCA outputs of it, make sure that it is connected to the chassis of the receiver. Most receivers have a ground terminal right on the back that you can loosen with your fingers and then put the ground wire from the turntable in there and tighten it hand tight. If it has no ground terminal on the receiver you can always just loosen a screw on the back and connect it there. Make sure the ground wire has the insulation cut back to expose the bare metal, that insures that you have continuity from the ground of the turntable to the ground of the receiver.
If your turntable has no ground wire, then you have a newer turntable type that would be able to plug into any of the audio inputs on the back of the receiver. It would be a turntable with a boosted signal that can only be connected to an input with the same level as the CD or Tape input.
I hope this helps you to figure out what your problem is, if you need more help don't hesitate to reply to this post. I will get back to you as soon as I am able.
If this was helpful for you a "FixYa!" rating would be appropriate and very much appreciated, after all, it is the only reward we get for helping people like yourself for free.
Thanks,
Dave
Sep 06, 2008 | Yamaha RX-V995 Receiver
Hookup
what turntable specifically....
jeff
Feb 22, 2008 | Denon AVR588 Receiver
No Sound from Turntable
It definitely has to go through a preamp (a PHONO preamp that is...) something like this: http://www.phonopreamps.com/tc400pp.html
Sep 14, 2007 | Nakamichi AV-7 Receiver
48 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
