Question about Electrolux EW23CS65GB Side by Side Refrigerator
My icemaker works fine but the auger does not work when the ice dispenser is pushed. There appears to be no power at the plug in the freezer. The auger motor appears fine and rotates smoothly. There is an control, relay box that supplies power to the motor, but I'm not sure where it is yet. Am I on the right track?
  • Electrolux Master
  • 4,655 Answers
Yes you are on the right track yet when it comes to Electrolux and Frigidaire refrigerators you will need to follow with me very closely on finding the reason there is no power to the plug at the ice auger. First remember that the door light switch must be pressed in when testing for power because the light switch acts as a lockout when door is open. Click Here=> Electrolux EW23CS65GB refrigerator components wiring diagram This Service Manual may not look exactly like your model but the wiring and parts are always the same. Also in this manual location of parts and component are listed and can be used to assist you in getting answers. Click here for available parts=> EW23CS65GB Look over your manual and ask me here or through my sites to help you solve this problem, Thanks, Sea Breeze
Begin on page 66 of the service manual, this is we will begin testing. Sea Breeze
Posted on Mar 23, 2011
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
GE Refridge GSH25JFXBB Ice but no water
This is solution to frozen water 'plug' preventing water dispense but ice maker still making ice. I first tried a suggested fix from this site to just leave dispenser light on overnight. I added some aluminum foil sealed over the module with a little tape to hold in heat. By morning still no water dispensed BUT I escalated the suggested fix by 1.) placing a large mug of boiling water in the compartment behind the aluminum foil 'cover' heat seal and 2.) added a small bean bag heating/cooling pad [heated in microwave] to the ice chute in the door from the freezer side. After one change out of the two 'heat sources' (about 30 min)...viola! Water dispensing again; proving it was an ice plug in the water dispenser. NOTE: When first adding the heating bag to the ice chute in the door, I found that a good bit of frost had formed at the top of the ice chute, so it appears this problem arose when someone (maybe even me) didn't close the freezer door completely due to overcrowding in that section of the freezer pushing against the freezer section door.
May 02, 2012 | Refrigerators
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
Jan 10, 2010 | Frigidaire FRS23R4A Side by Side...
We just inherited what looks like a 57029. We
No, but it is easy to disconnect icemaker. Unplug behind icemaker (remove or loosen screws to see plug. Put tape over jack in freezer to keep moisture out. Put icemake back when ready to connect water.
Aug 24, 2009 | Kenmore 57029 Side by Side Refrigerator
The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
Have same or similar problem. MY problem turns out to be that the Auger turns fine, but there is a little metal blade that attaches to the end of the auger and transfers the spin action into this auger "hopper" (for lack of a better term) which actually accepts the ice that has been moved from the back of the ice bucket by the metal auger and then dispenses the ice into the hopper which falls into the glass. the issue is one of crappy design. It turns out that this little blade has a rectangular opening in the middle that the rectangular end of the auger fits into. If this rectangle opening gets stripped (as mine has done, and ALL are likely to do) then the auger spins, the ice is moved forward but none are picked up by the hopper, and none (or very few) fall into the glass.
Everyone should check to see if this is the case. If so you may need to order a new blade, or a new auger, or a new refrigerator.
Good Luck!
Aug 10, 2007 | Frigidaire FSC23F7D Side by Side...
Electrolux EW23CS65GB  Side by Side Refrigerator Logo
202 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
