Question about RCA HD61LPW42 61" Rear Projection HDTV
On my RCA HD61LPW42 TV. I heard a short buzzing sound then a loud pop. I'm sure the pop was the bulb cracking (I checked) but I don't know what the buzzing was. I replaced the bulb about 18 months ago and the previous owner replaced the color wheel and had that triangle shadow problem fixed. Any way to check the color wheel to see if that's the problem? Thanks
  • 84 Answers
The buzzing sound you hear is the spark gap on the ballast circuit. It's what fires the lamp at startup. Perfectly normal.
Bill W
integrityhomeworx.com
Posted on Mar 23, 2011
Replacing bulb in hd61lpw42 rca. Question: I have replaced the bulb before but this time the glass covering the mirror is broken. I suppose the additional heat of the bulb cracked it. My wife said the...
lbcofer,
Just make sure that you purchase the entire module, not just the lamp. Also make sure that any glass is removed from the set. I have a tip at
http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv
which explains the process and where to get the best quality lamps at the best price. Do not use after market lamps or cheap lamps as they will explode as yours did and do not last as long as OEM lamps. In some cases they will not even be compatable with the equipment. The old adage about you get what you pay for, is definitely true in this case.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Feb 27, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a RCA 61" hdtv. i heard a loud pop and the screen went black. is this an easy fix?
see if you have a standby light on. if not then check fuse. if so then i would say this is not an easy fix.
Nov 10, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Heard a loud
Sounds like it could be your power supply board. Same kind of issue i had. Try unplugging your tv completely for an hour.
Apr 15, 2009 | RCA HD50LPW175 50" HDTV
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Black screen
Sounds like the bulb again. In the manual it says that the power light flashes to let you know that the bulb is bad. When I got a replacement bulb, I noticed that the wiring on it was opposite of the one on my set and had to change the wiring to match my set.
Jun 02, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
