Question about LG DLE2516 Electric Dryer
Lg dle2516 wont start. i checked the power to the power block and it measure good at 220v. nothing on the panels and the inside light is also not coming on.
Did you ever figure this out? Mine did the same thing today..died in mid cycle now nothing.
Posted on Aug 11, 2011
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
My LG electric dryer is not blowing any heat
Have you checked your circuit breakers to make sure they have tripped??
Look at the junction box behind the dryer where the power cord connects to the electrical system of the dryer. Open the panel and make sure that the connection is clean and tight. If it has any burn marks, you will need to replace the whole wire harness under LG's repair policy.
If these problems are eliminated, then you may have a problem inside the heating element or it's high limit switch which is inside the dryer and require disassembly.
Hope this helps.
Oct 31, 2011 | LG DLE2516 Electric Dryer
Hi I have GE Microwave (model no JES738WJ02) which has suddenly stopped working from yester day ... the problem is when I am starting it,the inside light gets on and the inside dish is rotating properly...
The easiest way to fix a problem at m.w. ovens is to check out if the 220V (Europe) volts feeds the transformer. You must remove the cover, put a glass of water inside the oven, turn on for 3 minutes and measure the tension that come to transformer.
Don't try to measure the transformer output, the tension is very high ~2400V !!!
If at the transformer input there are the 220V (Europe) but the oven still don't heat, the magnetron (m.w. generator) is burned out and must be changed.
Nov 14, 2017 | GE Microwave Ovens
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
My 38 hdc 024 carrier unit outside will not run
WARNING THIS A DANGEROUS REPAIR DON'T TRY IT UNLESS YOUR QUALIFIED TO WORK ON HIGH VOLTAGE!!
Tip: Never complete a 220v< circuit with your vascular system.
New Unit? wow wheres the installer? kk I'm assuming thats a dead end for some reason. Check for 220v at the compressor relay. I'm gonna go out on a limb and say your not getting the 220v power that you need to operate the unit. Do you have other 220v appliances such as a dryer or stove, if they are working properly that means that both legs of the 220v are making it from the pole to the house. Is the wiring in the breaker panel to the breaker that protects your condenser secure and tight. Are you getting 220v to that breaker? Is the wiring in the disconnect box by the condenser secure and tight? Are you getting 220v there? Is the connections to the compressor relay secure and tight are you getting 220v there. Is the compressor relay closing and are you getting 220v to the compressor? See how this works. Lol, Fun isn't it GL I hope this helped.
Jun 08, 2008 | Heating & Cooling
My dryers not working
If one of the lines is lost (230v circuits have to hot lines) the light only works on 1 line check your connections. There is also a thermal fuse that shuts the machine down when its overheating. If there is 230v at terminal block. The fuse is what i check next, well doorswitch too make sure the switch isnt broken (upper right of door). PLEASE RATE MY HELP
Oct 02, 2007 | Dryers
LG DLE2516 Electric Dryer Logo
127 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
