Question about Dell Televison & Video
I have a Dell T V model # W2607Cand I need to replace the main module # 715T1796-E. Who can I call for help.
    Master:
  • 525 Answers
Call Dell Support.
Posted on Mar 23, 2011
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
When i power on my dell laptop(model pp01l) it shuts right back off
you have a no post-no power issue... try to reseat the memory modules and try to turn the computer on with just one memory module first. if it doesn't power on, remove it and try the other one. if it still doesn't power on, motherboard needs replacement.
May 31, 2010 | Dell Latitude C640 Notebook
I am trying to find a video card to upgrade my Dell c610 the card is currently 16Mb. Any suggestions?
I'm sorry to advise you, your Dell is a laptop and laptops have a built-in video chip on the motherboard and it cannot be upgraded or changed.
The video card used shared RAM, ie it uses part of the main RAM module/s, You maybe be able to increase the video RAM size in the BIOS, but this will reduce the main memory, so you might want to upgrade the RAM in the DELL.
You only other alternative is to buy a later model laptop.
Dec 23, 2009 | Dell Latitude C610 16MB ATI Mobility Video...
At boot up my Dell Inspiron 8000 laptop gives a "Memory write/read failure" error message and will not continue booting. How do I solve this error and boot the laptop?
Check your memory, On the bottom of the computer is a small door to access the computer main memory. Check to see if it is not knocked loose - reseat it. and then it may be bad -and will need to replace it.
Nov 17, 2009 | Office Equipment & Supplies
Dell 50in plasma tv no picture no pcture or sound can here turn on power buttton is on can you tell me what part i need to replace
My friend, that's like cutting hair over the phone. First, you have to trouble shoot to see if the power supply is capable of running, and if it isn't, then you have to go into the main board and check for the 5 volts and the 3.4. If you have those then you must check to see if the power supply is getting the on command from the main board. If all that is operating then we go over to the Y sustain module and disconnect the VS and VA supplies from the power supply and see if your sound is restored. If it is, then there's a 90% probability that the Y sustain module is bad. That's about as close as we can get. I hope this helps. I suggest taking it in for a complete diagnostic check.
Nov 17, 2009 | Dell Televison & Video
Dell Vostro 1510 Laptop; cant get anything on the screen
Same thing happened to me.
I stumbled on this link and the solution made sense to me.
http://en.community.dell.com/dell-groups/new-to-community/f/3511/t/19323146.aspx
What I did was to nudge in the Hard drive to make sure it wasn't loose and press down slightly on the processor even though it didnt feel loose.
Worked for me. Though I'd help someone else since someone else 's post helped me.
Mar 20, 2009 | Dell Vostro 1510 Laptop
CD ROM MODULE WILL NOT LOAD SOFTWARE WANT TO BUY REPLACEMENT
CDrom Replacement for that model goes for $30 to $50
They're all over on ebay if you need to order one...
Nov 17, 2008 | Dell Latitude D600 Notebook
Mother Board Failure Where do you get a replacement.
ebay!
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board ... - eBay
https://www.ebay.com/itm/...W3706MH...Motherboard.../162597765902?_...
  1. Cached
US$59.99 - ‎In stock Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. ' eBay!
Dell Main Board 01004-2960 for W3202mh W3706mh ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components
  1. Cached
Used condition; • Returns accepted - 60 days money back or item exchange. Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. See details.
W3202mh W3706mh ' TV Repair Parts & Components Online
https://tvrepaircomponents.com/...motherboard.../discount-w3202mh-w3706mh__part_... Get the best deals on Part in our clearance section in addition to deals on motherboard board, board video motherboard, main video motherboard, main unit, un.
Dell TV Main Board ' eBay
https://www.ebay.ca > ... > TV Boards, Parts & Components > Dell TV Main Board
  1. Cached
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board Motherboard Unit. Model: W3202MH,W3706MH. Type: Main Video Board Motherboard Unit. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. C $74.81.
DELL 37" W3706MC 01004-3190 Main Video Board Motherboard Unit
https://www.ebay.ca > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
SKU: 01004-3190. Brand: DELL; Condition: Used; Notes: Please be sure that the BOARD Part Number and picture on your motherboard is EXACTLY as shown above. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV.
Mar 04, 2018 | Dell W3706MH 37 in. LCD HDTV
Akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
Upgrade Inspiron 2200 Memory From 512mb to 1gb
Good afternoon!
If you follow this link, you can download a copy of the users manual. Page 78 should give you the help you need.
http://support.dell.com/support/edocs/systems/ins2200/en/om/D88330a.pdf
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 12, 2007 | Dell Inspiron 2200 Notebook
Televison & Video Logo
59 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
