Question about AOC 7F 17" CRT Monitor
AOC 7 F 17" the OSD keeps on flashing
OSD keeps on flashing, i tried turning it off and pressed the menu button for 20 seconds. The screen became greenish the OSD still flashes. please advise
thanks
  • ilds Jan 21, 2009
    just keeps on flashing theres is no appearance
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Posted on Jan 07, 2009
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
Osd main controler lockd
Hi there.
OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
The HP Fixes
FIX 1
Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
FIX 2
Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
FIX 3
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
FIX 4
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
The AOC Fixes
FIX 1
Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
Currently these are the most commeon fixes.
~ Slasher_X
Sep 28, 2011 | Philips 190B6CB/27 19" LCD
I keep pressing menu and it tell me OSD Locked? How do I unlock it?
This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One:Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Envision 19" Widescreen Flat Panel LCD...
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
I get OSD locked and cannot change the screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock is displayed. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 26, 2011 | AOC Monitor
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
Osd locked , keeps flashing on screen
hi
vote me if you have your solution
Aug 11, 2010 | Computers & Internet
AOC LCD MONITER OSD LOCK
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
Mar 07, 2010 | HP M700 Monitor
Locked osd
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
May 21, 2009 | AOC 917Sw 19" LCD Monitor
AOC 7F 17" CRT Monitor Logo
746 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
