Hello, Try changing the plugs first and then the leads,and if that fails see if there is a spark between the leads and cylinder block. Also I presumed that you have new petrol in the tank,and if not change it. Even a little bit of sediment can make its way into the carby which also can be cleaned. After 3 years a lot can happen but it sounds like its not too serious as you have some starting even if only one cylinder. Also, try Ezystart, which is an ether mixture which they use for model planes, that'll start anything! Hope that helps.
