Question about Whirlpool WTW5560SQ Top Load Washer
Whirlpool Whirlpool WTW5560SQ Top Load: Stopped working after filling with water. Checked electric and circuits. First thought was lid switch, but no part number in manual. So where do I go from here?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The lid switch is likely the culprit. However, make certain the LH lid hinge screws are tight. If you cannot hear it click when you open and close the lid, it is bad.
Kelly
Posted on Mar 23, 2011
Testimonial: "Helpful, quick reply. "
  • 5 more comments
  • bltrainman Mar 23, 2011
    Smitty:
    Thank you. Is it an easy DIY? I am relatively handy. Any youtube videos?
  • Smitty Mar 23, 2011
    Yes, it is easily replaced. Remove the screws behind each end cap on the timer console and slide the timer console forward and hinge it up. The switch is on the RH side...you can't miss it!
    LH side...sorry! Kelly
  • bltrainman Mar 25, 2011
    Kelley:
    I replaced the lid switch with a new one, but still not working. It fills with water, but does not move on to the next cycle. It just stops. Any other ideas?
  • Smitty Mar 25, 2011
    Are the screws for the LH hinge on the lid tight? You may have to measure voltage to the motor coming form the timer. Do you have a meter to test for voltage?
  • bltrainman Mar 28, 2011
    The lever on the LH hinge that triggers the lid switch is loose. It does not enage the switch completely. I should be able to tighten it. Thanks.
  • Smitty Mar 28, 2011
    Very nice, great investigative work! That should take care of your problem!
Whirlpool Ultimate Care II LSB200KQ1 Top Load Washer - the washer filled and then stopped. No humming, no sound, no action when we turn the knob. Thoughts?
The limit switch that detects that the lid is closed is probably defective. You've already probably experienced how the agitator would stop if the lid was opened when the machine was working properly--same thing.
Jul 17, 2012 | Whirlpool Washing Machines
The washer filled with water then stopped. It will not agitate.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If I understand the problem, the washer WILL FILL but WILL NOT agitate or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jul 12, 2010 | Kenmore 22642 Top Load Washer
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Well, we got the washer from a friend. she said
maybe the tub is just stuck from sitting for a year,put in on spin and try to jump turn the tub to get it going-mike
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
My top loading whirlpool washer stopped after filling. Cycle dial does not engage any agitating, spinning,rinsing, nor draining activity. The dial does not advance with time, neither. Checked the outlet...
You could have a bad lid switch or a bad water level switch or a bad timer. In that order.
Open the control panel to access the components listed.
Make a small wire jumper and jump out the lid switch. Turn the timer on and see if it works. If yes, replace the lid switch.
If no, check power from the water level switch to the timer.
Terminals V to T should read closed on a meter set for ohms.
If the water level switch is closed the timer is bad.
Apr 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer stopped full of water, will not click etc
possible bad lid switch..if switch cks ok ck for wiring connection on motor
Nov 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is dead.
Check your washer plug carefully & the fuse in the plug..............may sound silly.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool WTW5560SQ Top Load Washer Logo
132 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
