Question about Vizio High Definition Sound Bar
Can you hook the vizio sound bar to an av receiver for use with all devices hooked to the receiver thru HDMI?
    Brigadier General:
  • 8,546 Answers
Why not ? It doesn't know what the source at the other end of that RCA or digital cable is.
Picking the VSB200 as an example.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
Posted on Mar 23, 2011
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
Jan 01, 2016 | Vizio VSB210WS Soundbar
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
How to connect a vizio sound bar to xbox 360
You can use the original cable just plug the sound in and thin the part hooks up to your xbox take the cover off so u can hook your hdmi back up thats it.
Dec 31, 2010 | Vizio VSB210WS Soundbar
I have a Pioneer reciever that does not have a hdmi input, also There is 1 optical input on it that my cable box is hooked up to. I have not opened the ps3 yet because I'm not sure how to get the sound to...
ps3 comes with an av jack set as well as hdmi. now you can use the hdmi to the TV and run audio out from the TV to the receiver and that should work but if you don't have audio out on the TV then you need to go get the av cable
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
Vizio L37
Sounds like a bad av connection on the main board. i would try to connect the xbox via an alternate av connection or hdmi to verify problem. contact vizio support and describe your problem. they have had trouble with this main board. some of their parts have lifetime warranties and the service call is free. changing out the main board is a pretty simple process, about an hour or less. hope this helps.
Sep 28, 2008 | Vizio L37 Television
Vizio High Definition Sound Bar Logo
1,382 people viewed this question
Top Vizio Audio Players & Recorders Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
