Question about Maytag PER5710 Performa Electric Kitchen Range
Gas smell is strong on Maytag Performa when using the oven.........some times?
  • Maytag Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Mar 23, 2011
A tenant of ours is saying that their Maytag 27" single oven of: Every time we turn on the oven, there's a very strong gas smell for at least the first few minutes. The oven is heating ok.
you should probably go over or send someone ASAP to pull it out and check the lines are connected properly and haven't become damaged.
Could you imagine the lawsuit and property damage if their was a gas leak. This is the very reason gas has an odor added, it is the only warning sign of a potential leak and explosion.
I would take this very serious and give immediate attention.
Nov 15, 2016 | Maytag Ovens
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
I turn the oven on but smells like gas the pilot light glows but know flames come out of the tube. it use to take a while for the flames to lite up but it smells like gas.
Hello- You will need to replace the Ignitor. This problem is a common issue with gas ranges and any appliance repair company should be able to help you and have the part. Best regards.
Sep 27, 2010 | Maytag PGR5710 Performa Gas Kitchen Range
Can light the oven pilot light but it won't stay on when I turn the dial to oven temperature. I cleaned the oven prior to this problem with spray on oven cleaner.
I have a 2003 maytag performa stove and i turn the oven on but sometimes it takes a while to come on and smells like gas so and lately i cant get the flames going. i see that the pilot glows but still know flame coming from tubes.
Sep 27, 2010 | Ovens
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Trouble lighting oven, smell gas
Sounds like an igniter problem to me. They are heating elements with a limited life & are quite easy to change. There is one for the broiler on the top as well. Why not try swapping them to confirm this diagnosis. If you never use broil then your problem may be solved!
Dec 23, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Matag gas oven won't or is slow in comming up to temperature.
Hello and welcome to FixYA!
You are 100% correct in your suspicion that the oven ignitor is at fault. If you want to know "for certain" you can check that ignitor in circuit using an amprobe and looking for at least 2.9 amps, however I would say all you need do is replace that ignitor and your oven should return to proper operation. The gas smell is a result of an ignitor being on the "ragged edge" of being able to open the warp switch in the gas valve. Instead of opening up, it is "burping" the valve enough for you to smell gas. Your part number is a
12400035 and sells for around $50 or so, depending where you buy it.
Thanks for using the FixYA! service!
Dec 14, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Maytag PER5710 Performa Electric Kitchen Range Logo
340 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
