Question about RIM BlackBerry Bold Smartphone
Email waiting red led doesn't operate when expected and have not been able to find the option to turn this feature on
Go to Option - Sound and Ring Tones - Sounds for Selected Profiles.
Posted on Mar 23, 2011
Charging light shows green--manual says charged when light goes off-_I would expect a red light when charging--Is it charged when green light shows???LUMIX ZS8
Hi if u r using DE-A60 or DE-A60A CHARGER / when charging green LED is on when fully charged LED Turns off ...cheers
Nov 01, 2017 | Health & Beauty
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
Thanks for the suggestion budddy but the prob is that there is no 'play' option.In place of play option there is only the option of 'copy'. Guide me. Thanks
The shortcut for the game should be in this folder in Windows Explorer:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games
if you can double left click the shortcut there the game should launch. If it doesn't, then in Programs and Features, there should be a turn Windows Features on and Off option on the left side. Uninstall the games, reboot, the reinstall the games the same way, see if anythign changes
Jul 27, 2011 | Computers & Internet
Will a Phillips Universal operate a Samsung DVD-2000, and what ar
YES! if you have a universal remote look in its manual and program the code for your samsung into it. there are some buttons like SET and TV1 2 etc Select TV1 and SET buttons a red LED comes on, enter the code (eg: 013) the red LED goes out Press set aain and then press power on remote TV shoulod turn off if it doesn;t try anothyer code until you have control of the TV
Aug 11, 2009 | Samsung Televison & Video
Projector won't power up but red light is on
This is from the manufacturers website...
When I try to turn the projector on, the warming indicator (red LED) blink.
The projector is in the default configured lockout state, and the Panel is waiting for its internal lockout
timer to expire. This feature protects the projector’s bulb. Be sure to let your client know about this
behavior.
So i guess you have to wait for that timer to end?
Jun 23, 2009 | Sanyo PLC XU35 Multimedia Projector
Automatic address, compose, forward, does not work.
Completing addresses when addressing an email works a bit different as Outlook doesn’t have an AutoComplete feature but has an AutoSuggest feature a Check Names feature instead.
The subtle difference between the two is that the AutoSuggest feature doesn’t have a direct relation to your Contacts folder or other address lists configured in your Address Book. Instead, AutoSuggest uses a cache which contains a list of addresses that you’ve previously used.
Outlook also has another feature which is similar to AutoComplete; Check Names.
Check Names can work interactively and by default also works as a background process.
Check Names – Interactive
To use Check Names interactively, you type part of the name or address and then press the Check Names button on the Toolbar or Ribbon or press its keyboard shortcut (for most localized versions this is CTRL+K). This will search in your Address Book for that part of the name. If only a single address is resolved, it will directly show this in the To-field (or CC or BCC field). If multiple addresses are found, then it will prompt you with a dialog to select the correct address from.
Check Names – Background
When you only type part of a name or address and then switch to the message body, Check Names will perform a background search in your Address Book. If only a single address is resolved, it will autocomplete the address for you. If multiple addresses are found, it will underline the address with a red scribble line.
When you press the Send button while an address is not fully resolved, you’ll get prompted to select the correct address.
To turn of this background feature of Check Names go to;
Tools-> Options…-> E-mail Options…-> Advanced E-mail Options-> disable option: Automatic name checking
Apr 21, 2009 | Computers & Internet
Can you help me?
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 24, 2008 | RCA Universal Remote Control
RIM BlackBerry Bold Smartphone Logo
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
