Question about Maytag PYE2300AY Electric Dryer
The dryer do not want to turn on. I have already check the breaker box and it was okay. I also tried each setting on the dryer and it still would not work.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The fuse is likely open. I have posted a picture of where it is
Kelly
Posted on Mar 23, 2011
Dryer Won't Start
Cam,
One thing you can check on if the circuit breaker is okay is to see if the drum turns freely. If the belt is still intact, you should have some resistance to turning the drum by hand. Many dryers have a safety in them that if the belt breaks the dryer will stop and not restart until the belt has been replaced. Hope this helps!
Nov 10, 2014 | Dryers
Dryer wont start all the sudden
Hi, in order to help you fix your problem we first must address the obvious . First things first go to your homes breaker box locate the breaker for the dryer ,flip it off and then back on. Sometimes even if the breaker does not look tripped it can be. If the dryer still has no response ,you may still have an issue with the dryer plug or the dryer cord . Assuming these are okay most likely the dryer has blown a thermal fuse,a small typically two wire safety device. Normally located on the discharge duct of the blower/ drive motor. The thing to remember is it probably blew either because of age,or a restriction in the dryer hose or vent. If not remedied could pose as a fire hazard and should at the very least be inspected. And depending on your skill set,I would not attempt to disassemble your dryer unless you have the necessary experience .just make sure that whatever you do ,you turn the power to the dryer off at the breaker...hope that helps..
Dec 18, 2011 | Roper Dryers
My GE profile model dpgt750ec dryer will not turn on - checked breaker okay, light comes on inside the door, but no power when attempting to turn on
Recheck breaker turn the breaker all the way off and then reset the breaker. Then try a different cycle. like air only or something different than you normally use and see if it works then. Motor could be out or The control switch. Make sure you are looking at a double pole 220 breaker. hope this helps.
Dec 19, 2010 | GE Profile Harmony DPGT750EC Electric...
Will not start, already checked breaker box and plugs.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 03, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer was working the just stopped and won't start back
check your main breaker box first, see if it tripped, if the breaker looks okay then turn off the breaker for the dryer and reset the breaker switch, if this still doesn't work then a fuse has popped on the circuit board.
Sep 13, 2009 | Amana NED5400TQ Electric Dryer
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer wont turn on
it sounds like the door switch or main fuse has blown,check the door switch,click it in and out to see if it has the clicking sound,if not replace,you can check the main fuse by removing the back panel,it is located on the blower box,let me know-mike
Mar 02, 2009 | Whirlpool LER4634J Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
35 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
