Question about Dual Electronics XDM6350 Car CD/ MP3 Player
When connecting iphone in usb port, display stays reading and nothing happens on dual xdm6350
  • 12 Answers
ANSWER:
The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON:
The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer.
Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION:
You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck!
- Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Posted on Jul 28, 2011
MY USB port says reading when i connect a USB drive. WHy?
ANSWER: The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION: You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck! - Chris Proia
Jul 15, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
The USB port on my Dual xdm6350 will not work anymore. It will not read my Ipod. and my ipod still connects to my computer
the USB port does not play music it only charges. the AUX is were you plug it in to get the music. If thats not it then it could be your cord. I had the same problem awhile back.
Apr 28, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
When I connect my usb to my ipod it just says "reading"..
ANSWER:
SOLUTION:
Good Luck!
- Chris Proia
Apr 09, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
Trying to install an XDM6350 Dual Stereo system into a 2002 F150.....need a wiring diagram.
Here is the User Guide for the XDM6350:
Go to the "Installation" section and there is a wiring diagram there.
Jan 29, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
My dual xdm6350 won't read or charge itouch... It just says reading. Any suggestions?? Thx
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Oct 13, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
When I plug my iPod into the XDM6350's USB jack, it keeps saying "Reading," and never goes any further than that. I've given it a really long time, though I don't have that many songs on my iPod, but it...
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Aug 03, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
I can't charge iPhone, I got power surge warrning on my computer
hello friend,
maybe your cable of charging is nit genuine,
if warning displays in your phone then there is the problem in cable
and if the error displays in computer then the problem should be in battery or main board
Apr 22, 2010 | Apple iPhone Smartphone
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Dual display support
nothing, you just get two display there.
Feb 24, 2008 | ASUS A7S8X-MX Motherboard
Dual Electronics XDM6350 Car CD/ MP3 Player Logo
163 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
