The washing machine will not work it just shows F 26 on the machine, and continues doing the samething
    Brigadier General:
  • 6,277 Answers
Sorry, you do not say the make and model of your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
How do I repair F 26 on a Kenmore frontload washer
if you get the F26 error code, Press Stop, Open the door, press the black button just above the right middle of the machine opening, above the latch, hopefully, you will also hear a click, and then your machine will work normally.
Sep 01, 2014 | Kenmore Washing Machines
What is an F3 26 error?
Appliance tech has a computer program or hand held device that has the answer. Newer machines are built to that spec. F3 shows where the main component of the error exists. #26 may not be a commonly occurring error. Go to Google and type in F3-26 or something similar. See what happens. Failing that contact a repair Company or your trusted Tech.
Jun 28, 2014 | Samsung WF337AA Front Load Washer
Why is there an 'SF' code showing and continuous beeping from our Simpson encore 756
there are different sf codes for different faults. try googling the sf number fault to find problem.
May 25, 2014 | Washing Machines
How to clean the washing machine?
simple;buy a washing machine cleaner from your supermarket,they are out there in the cleaning isle, or buy a dishwasher cleaner samething.adrian,,,
Dec 16, 2010 | Ariston Technologies Ariston AWD12 Front...
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Nov 24, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
