Question about Microsoft Xbox 360 Console
I just bought and replaced my drive for my xbox 360, and it reads movies and cds, but it reads my games as a dvd, and says play dvd. When I select it is either stays on the xbox logo screen, or it it says to play, put into an xbox 360 game console...How can I fix this?
  • deucehearts Mar 23, 2011
    Did you replace the DVD drive or the Hard Drive?
    Novelist:
  • 102 Answers
Sounds like the DVD drive is going bad. Pretty soon it'll stop reading everything.
You could replace the drive yourself. Just buy a replacement drive off eBay/Amazon or some other retailer. The issue with that is that the Xbox 360 DVD drives are designed to
only work with the Xbox it came with, so you'll have to do some fancy stuff to get the replacement to work in your Xbox.
Here's a link to replacement drives.
Here's a link to a guide (with excellent visuals) on how to actually replace it.
Too complicated? Just send it back to Microsoft, let them sort it out. If you're under warranty it should be free; otherwise, it'll cost you some money. Here's a link to their service center. (If you send it in, remember you keep your hard drive! They might not send it back if you forget.)
Hope it all works out!
Posted on Mar 23, 2011
I replaced my disc drive, but my xbox only plays movies and cds, no games???? I need help!!
Hi.
Because you have replaced the DVD drive it may have a Lost DVD Key.
Xbox 360 DVD drives are Married to the motherboard of the console that they came with. If you simply replace a faulty drive with a working one, the console will not read game discs, only DVDs and CDs. You need to either repair the original drive, or swap it's controller board with a drive of the same model. (There are a few different drive variants, so you need a drive of the same model) If repairing the drive and putting it's controler board into an identicle drive doesn't solve your problem, there is really no possibility of regaining game functionality.
Regards.
Jun 03, 2011 | Microsoft Video Game Consoles & Games
I got a 360 off ebay and it wont read 360 games but will read cds and dvds, whenever i put a 360 game in it says to insert disc into an xbox 360 to play, can you tell me wants goin on please?
You need to replace the dvd drive . most online shops like console sourceDotcom have the replacement dvd drives to specify the dvd your have you can open your 360 and look or go to google and search LLama mods and there you find the types of dvd drives pick out the 1 that matches your dvd drive and place an order and they have all the how to's on how to install your new Dvd drive for your xbox 360
Aug 04, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
My 360 only plays cds or dvd s wont play games please advise
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
Feb 15, 2010 | Microsoft Xbox 360 Console
My xbox360 will not read disc, message reads
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
For disc-specific issues, check the disc for any visible signs of damage or dirt. Hold the disc by the edges without touching the top or bottom surfaces with your fingers. Clean the disc by using a soft cloth. Lightly wipe from the center outwards. Do not use solvents or chemicals to clean the disc.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked also if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Let me know of this helped and please do take time to rate my solution
Happy Gaming, Happy Holidays
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Premium System for Xbox 360
Reading cds but not xbox games
Your DVD drive's laser is malfunctioning.
You have a few options:
1) Decrease the resistance on the laser to increase power, and it may be able to read the discs again. A guide for that can be found here.
2) If that doesn't work, or you do not wish to do that, you can replace the laser head all together. Replacements can be found on eBay. You can follow this guide to replace the laser head.
3) You can replace the DVD drive completely, but it will require taking the original drive's firmware and putting it on the replacement one. The guide for that can be found here.
Dec 06, 2009 | Microsoft Xbox 360 Console
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 drive wont read games it will only dvds and cds
Your laser either needs to be cleaned or is going bad. I have seen this many times before. Try taking the drive apart and cleaning the laser aperture with 91% alcohol and a cotton swab (carefully). If that doesn't work then you need to replace the laser (or get a new drive).
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_b1cdba8db959d216
Jun 08, 2009 | Microsoft Xbox 360 Console
"Disk is unreadable"
Since CDs and CD-R's work fine, its probably that the disc tray of your xbox 360 is not working. you might wanna try contacting xbox customer support to check the warranty status of your console. might as well send it in for repairs
Mar 23, 2009 | Microsoft Xbox 360 Elite Console - Black
Installed new Xbox DVD ROM, but cannot read games
The DVD drives must match the motherboard that it came with. Unless you go through a very complicated re-flashing process. If the motherboard and DVD drive do not match, it will not play 360 games
Dec 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
76 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
