My maytag mah7500aww control board seems not to work anymore. on the top left corner of the control board there's a 1"x3" aluminum plate that get very hot
  • 236 Answers
SOURCE: Maytag Neptune MAH7500AWW will not fill from hot water side
check out the hot water tap is on then check out the hot water valve for continuity (poss 27 ohms) then check for blockages in the small inline filter at the valve.
Posted on Jan 20, 2008
Master_Tech
  • 770 Answers
SOURCE: control board
have you the touch onsole first to se if it was ok there have been more problems with tha then the cpu board? do you get any beeps while touching it??
Posted on Aug 23, 2008
SOURCE: Maytag top loader slight leak from bottom left corner
Thank you for responding. Yes we fixed the problem. After taking off the front cover noticed the hose from the liquid bleach dispenser (which I never use) was not connected. Evidently when using the extra large load a little water would splash into the bleach dispenser, hence the small amount at bottom front left corner where dispenser is located. So simple! Glad I didn't pay for someone to attach the hose. Thanks again for your timely response. Lynn
Posted on Mar 31, 2009
  • 119 Answers
SOURCE: leaks
sound like the fill spout aereator
Posted on Feb 11, 2010
  • 3289 Answers
SOURCE: I Have a Maytag MAH7500AWW
An MOV is a "metal oxide varistor". This is a very common heart of a surge suppressor, which can be used "across the line wires" to prevent harmful voltage spikes from adversely affecting equipment. Most of the time however, an MOV will sit idle in a circuit for years, then one day, it gives its life blocking a voltage spike. You use the equipment the next day like nothing happened. Everything works fine - until the next voltage spike.
Your MOV has already activated, and is no longer able to provide the protection it once had. As a result, the next voltage spike passes unobstructed by the failed MOV into the circuit ruining the circuit.
The problem is that the MOV never told you it failed. Many times, a number of MOVs are installed all at once - each one fails at each subsequent voltage spike. It could take years, decades or more before the last MOV fails - likely long after the warranty is over.
You can probably see that the failed 50 cent MOV isn't the problem any more. It was *before* the circuit failed, but you never knew it had failed. Now, the latest voltage spike fried the circuit and it will require wholesale circuit board replacement or labor intensive troubleshooting to locate and replace all the failed parts on the circuit board.
You're better off buying a used board or an entire used machine until you can fix this one.
I hope this helped you understand about MOVs, and that replacing this part will not restore the machine to working order.
Posted on Sep 09, 2010
Maytag dishwasher no lights and left water in pan
I am a homeowner. I do have a maytag dishwasher as well. It may be a control panel problem. You will have to expose/remove/examine the control panel circuit board by removing the top six screws on the door. (I don't think you have to remove all of the screws: just the ones securing the control panel to your door. On my dishwasher the screws are: one on each side of the latch (so 2 screws here), then one one each top corner (so 2 total screws at corners), and finally one screw along each side edge : altogether 6 screws. To expose the inside you will have to remove covers that are secured by tabs. Upon examining my circuit board I found a disgusting nest of cockroach eggs, waste products that probably corroded my board and ribbon cable. Apparently the cockroaches love the warmth of this area. So if you have cockroaches in your house this may be the cause of your problem. I replaced the circuit board and now my dishwasher runs just fine. (I had different dishwasher symptoms but still it may be a circuit board problem)
Nov 08, 2017 | Maytag Dishwashers
I need owners manual for maytag washing machine modile mah7500aww. Maytag web site has parts repair list pdf. only.
i am not finding a link on maytag.com for that manual. However here is where ya can go for a very good setcion by section breakdown of part numbers complete with drawing http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MAH7500AWW/3048/0153200?pathTaken=&prst=0&shdMod=MAH7500AWW
Gene
Aug 20, 2011 | Washing Machines
Hello, I have a DTI704 that has recently stopped working after some electrical work in my house. After turning on the induction hob, the only buttons that seem to work are for the Top Left and Bottom...
call the technician for a proper diagnosis amn quote
unless the electrician doing the wiring altered the circuit to the unit , there will no connect for the fault
May 24, 2017 | Ovens
My Neptune washer MAH7500AWW says that the washer won't lock to work. It does this on and off. How do we fix it?
You may have to change the wax motor (lock) on it. Before you door so though check the board in the control heading for a burn mark on the R34 resistorwhich is located near the middle of the board. If its burnt change both parts out or it will keep doing the same thing.
Nov 02, 2010 | Maytag Neptune MAH7500WH Front Load Washer
How to remove motor from maytag washer lat4916aae
some have screws that are at the bottom of the front panel and some just pry off..lift front cover from bottom swing out and up to release from top. motor is in left front corner. remove wiring and top cover and screw on plate mounted to floor in left most corner/front of plate. remove motor and plate. flip over and remove nuts holding plate to motor..install reversely.
Jun 13, 2009 | Maytag LAT3600A Top Load Washer
No model number anywhere on the range
Reach behind the upper-left corner of the control panel. There should be a 1"x8" aluminum flag that can swing up. The model, etc. is on there.
Jan 17, 2009 | Maytag MER6872BAS Gemini Electric Kitchen...
Commercial Energy Advantage High-Efficiency Front-Load Washer MAH22PRAWW
Take the front panel off, (12) screws in all. Start by the soap drawer (2 t-20's {safty type}). Then loosen the 4 T20's (also safty type) that hold on the aluminum face plate & display lens. Now the front meatl cover can come off (there is a snap clip by the soap drawer). Now remove the 6 - 1/4" inch screws 2- hold the top down, the other 4 hold the control board on. Now remove the control board & turn it over. You will see a white 3 pole connector plug, by it on the board it will say " service & coin". Remove the plug, now look at the display & you will see the error code. It will either be a "D" or an "F" code depending on your setup. Now push the lower left button on the panel (Delicates & Knits). your display should read 600 or 6 and a couple #'s (this is coin count). Replace the plug & your reset. Now just put it back together. Remember the display lens has a small window that need's to go bact into the upper left corner. I'll bet it will be an F22 or D17 - either way be carefull about closing the door (make sure nothing is caught by the door and boot seal). D8 or F21 -means long drain watch how much soap you use 1/4 cup or less is best. I hope this helps you.
P.S. keep track of the error codes- Maytag/Whirlpool may owe you an upgrade on the machines software.
Sep 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune MAH7500AWW Speed Indication Error - Won't spin up...
Sorry, I cannot solve this. I just wanted to post a couple of useful tips for anyone else out there who happens to be diagnosing their MAH7500AWW.
1. You can put the washing machine into service mode by pressing the <back> and <help> buttons for 5 seconds and then releasing.
2. There is a large folded troubleshooting schematic located under the top console. You have to remove a few screws and lift it up to pull it out.
Sep 19, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Control board
Aug 23, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Washer door would not open
Hi Harold From my parts breakdown too That part is $580 its so expensive because it a touchscreen LCD. I have had some (nonLCD) models doing this and it has been the Main Board sometimes, you may want to pay for a 2nd opinion. Where is Hudson?? Im in Tallahassee
Oct 16, 2007 | Maytag Neptune MAH7500A Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
