Question about Juicelady The Juice Master Juicer
How to take apart juice master jr and clean. it appears stuck, pls help
Pusher stuck in fusion juicer
May not be repairable if pusher is distorted or damaged. If jammed with a foreign body, need to carefully pry apart and clean out. Find a handy person and offer a fine juice meal.
Nov 25, 2014 | Juicers
JUICE MASTER MODEL NT 9214/32597, HAS NEVER BEEN USED. I NEED INSTRUCION MANUEL.
I have home juice extractor FIRST Model No NT-9214, Nr : S 9352152.
I am very happy with it, but I damaged the plastic parts.
I'm from Slovakia, I live in the city Nitra.
For these extractor in service no longer have replacement parts.
Please help me and talk to me where can I buy these parts.
Please answer to my e-mail address imrich.macho@gmail.com
Thank you
Sep 18, 2011 | Salton Jr. JM1 Juicer
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
Unable to take juiceman apart to clean
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Jan 25, 2009 | Salton JM411 Juiceman II Elite Juicer
Rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Jul 15, 2008 | Juicers
Jack Lalannes power jucier
a tool is provide to rlease grating cone. if lost use a pointed scussors.
Apr 01, 2008 | Juicelady The Juice Master Juicer
Pulp gets stuck in Champion
Feed it slower. Mix up the items, it likes things mixed up. You can add water near the end to clean it out.
Jan 20, 2008 | Champion 2000+ Household Juice Extractor
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Juicelady The Juice Master Juicer Logo
226 people viewed this question
Top Juicelady Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicelady Juicer Expert? Answer questions, earn points and help others
