Question about Kitchen Ranges
Plef398ccd model top element won't shut off. combination small and large eye won't turn off small element.
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Frigidaire glass top
You will need a wiring diagram and a multi-tester (volt meter, etc). Find the diagram for the elements, trace your wires to that switch, and check for voltage coming out of that infinite switch. If you have voltage, then its your element (85% chance its the element anyway). Good Luck.
Posted on Nov 05, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
allbrands
  • 600 Answers
SOURCE: mod # MER5710AAW The small element will not heat
chances are the infinite switch failed i would replace the switch for the small burner Part #: 7403P238-60 this should fix your problem.before ordering the part just make sure all the connections ar good on the switches after removing the back panel. hope this helps
Posted on Jun 07, 2011
On the stove each eye has to settings you can either turn on single high medium or low or dual high medium or low I don't own the front I don't understand what that means what does that mean
It has two sets of elements, a single one in the middle if you a cooking a small item, or dual elements that cover a larger area for cooking large items. This works for the top hobs, and also for grills/broilers in many stoves. If save electricity, and also having heat outside the base of a small pan. I see yours says 'Accusimmer', so it is a Whirlpool and it is the top hob.
If you Google
make model manual
You will probably find it online. Here is some information
whirlpool accusimmer manual Google Search
Feb 21, 2018 | Kitchen Ranges
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 31, 2012 | Dryers
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Large eye thermostat is not working. Heat stays
Hello JBlum, Yes, most stove top elements, including those with the thermo sensors, are replaceable. Without the model number, I can't steer you towards the exact part number, but you can look it up yourself at www.searspartsdirect.com
Just enter in the full model number of your GE range and it will bring up all the line drawings and parts lists for it. You can either order the parts from Sears, or use any other supplier you wish.
Just remember to disconnect the range from the wall outlet before you undertake any repairs or attempt to replace any parts, so you'll be safe.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | GE Cooktops
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
