Question about SanDisk Audio Players & Recorders
The unit won't turn on and freezes up. It's only 3 weeks old. I have 2 others which have never been a problem for 3 years.
  • 2,418 Answers
See my tip posted here, > Frozen MP3 player. If using my tip does not help with the player, go to Sandisk support and download the updater program.
Posted on Mar 23, 2011
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Ek Dada, Ek Bap, Ek Pota, Tino ki age 140 yers. Pota jitne month ka dada utne sal ka, pota jitne din Ka,.Bap utne week ka, WHAT IS THE SOLUTION?
OK here it is.
Dada is 84 years old (grandfather)
Baap is 49 years old (father)
Pota is 7 years old (grandson)
Check: 84 + 49 + 7 = 140 years
Read below if you want to know how to solve (Its a simultaneous eq. of 3 variables bdw :)):
Let Dada be D years, Baap be B years and Pota be P years
D + B + P = 140 (given)----------------------------- (1)
Constraints:
D = 12P; --------------------------------------------------- (2) 1 year is 12 months; 52 weeks; and 365 days
52B = 365P; --------------------------------------------- (3)
Substitute value of P from (3) into (2) therefore D = (12 * 52/365)B ------------------- (4)
Put (4) in 1 to get
(12*52/365)B + B + (52/365)B = 140
This gives B = 49 years. Put in above eqs to get other values.
Dec 04, 2010 | Computers & Internet
My unit is 3 years old. We have recently heard
sounds like the evap coil is freezing. it is frozen if you have low air flow. check the lines and see if your suction line is freezing. also check your filter. if you think your drain line is clogged cut the line and blow out with an air compressor or nitrogen. all you should need to fix the line would be a 3/4 in coupling or a union. hope this helps
May 31, 2010 | Goodman CLQ60AR61 Air Conditioner
I have a Jantrol heat pump & A/C. It is approximately 10 years old. For the last 3 summers the compressor unit will freeze when the air handler fans fails to come on. It worked fine for 2 weeks this...
If you can safely check the supply to the motor when it should be on, then this is the best method to check it.
Check the fan turns very freely - oil the bearings if it doesn't.
If there is power there, but it does not turn, replace the run capacitor.
If this get's you going - Please rate as Fixya so others may benefit. Thanks!
Jun 26, 2008 | Goodman Heating & Cooling
Defrost issues
If it's around 2-3 years old, my first guess would be the heater is bad. The GSS models have problems with the heater almost always about that time.
Test the heater and the defrost thermostat for continuity with a multimeter. Whichever one doesn't get continuity is bad and should be replaced. If they are both good and the evaporator fan is running like it should, it will be the main control board located on the back of the unit.
Click here to see the defrost heater
Click here to see the defrost thermostat
Click here to see the main control board
Let me know if you have any other questions about this issue.
Mar 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
HLN567w-won't start amongst other things
HEY HRABOSKY,ONE COMMON ISSUE AMONG THE OLDER SAMSUNG DLPS' ARE POOR/DEGRADING SOLDER JOINTS ON THE DIGITAL PC BD.(THAT'S THE BIG SHIELDED ONE FACING THE BACK).I'VE HAD GOOD LUCK RESOLDERING ALL PLUG INTERFACES AND SET WAS FINE. JOE TV
Oct 21, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
