Question about Cisco ATA 187 Analog Telephone Adaptor ATA187-I1-A=
Using Cisco Call Manager 8.0.2 ATA 187 was not on device list so it would not register ATA 187 SIP Only I installed the firmware and device enabler for ATA 187 to Call Manager. The device type now shows up in Call Manager but the ATA 187 still will not register to Call manager. Went on Web interface to see if the device would show up. It does, and says that it is registering, but it still will not show up in Call Manager.
Rubec
  • 42 Answers
SOURCE: cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Posted on May 09, 2008
SOURCE: cisco 7912g sip firmware
firmware can not be e-mailed to you unfortunately. The only way to oficially obtain the software - purchase it
Posted on Jun 09, 2008
ward_knutson
  • 64 Answers
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
  • 97 Answers
SOURCE: KONCEPT CISCO
If that is going across a routed network, check all your routing configuration. A lot of 'one-way' calls are caused by incorrect routing.
Make sure that the subnets for each of the phones can get to each other, and if possible try putting them on the same subnet for a trial to make sure that works.
Hope that helps!
Posted on Oct 17, 2010
puertobori
  • 7733 Answers
SOURCE: I have error 211 Your Adapter may not be installed
Go to Linksys by Cisco.
Posted on Oct 19, 2010
How to upgrade to SIP Firmware on Cisco 7945G
This process should work for you http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Cisco Telephone Power Brick
Sep 08, 2012 | Cisco 7945G IP Phone
Cant get scanner to work
PROBLEM SOLUTION :
1. Don't install software/drivers form the HP CD. If already done, uninstall them using setup.exe from this CD
2. Connect the psc2210 USB cable to the PC. Windows will load divers from Internet but will not be able to install two of them: "psc2200 Series" and " Hewlet Packard psc2200 Series ". Repair assistant will not be able to fix the problem either (probably the Windows 7 bug).
3. In the « Control Panel->Hardware and Sound services », activate "Device Manager" found under « Devices and Printers ».
4. Under « Other devices » look for « HP psc2200 Series » with a small « bulb » icon, bearing a yellow question mark. . Select « update driver » for this icon : Windows scans Internet and installs the related driver , followed by the message « Windows has successfully updated driver for your device HP psc2200 series »
5. In « Device Manager the «HP psc2200 series » now appears under « Imaging Devices ».
6. In the Control Panel, under « Devices->Printers and Faxes » the icon of the HP psc2200 series is now shown without the error warning. Clicking on this icon offers several choices, "Start scan" being one of them
Jan 14, 2011 | HP PSC 2210 All-In-One InkJet Printer
Having issues with logging into the cisco softphone from home via vpn
Make sure that the subnet for the call manager is available over your VPN if you have locked the tunnel down. Also make sure that the IPC is allowed to bind to the VPN virtual network card.
Hope that helped!
May 19, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
My handy tone-486 box keeps flashing red every 3 seconds and I have no dial tone. My internet works and I have power and a working phone line to the box. Help.
Lifted this straight from the manual:
Button flashes every 4 seconds
(if SIP server is configured)
HT–486 fails to register
So basicly, that means your HandyTone 486 ATA fails to register with the SIP-server. That means you either have not recieved your IP-tele yet, or that your ISP have failed to register you.
Mar 04, 2010 | Grandstream HandyTone 486 ATA (HTATA486)
Can I use a CISCO IP 7941 phone, that has been on a company network, in my home? Should it just work by plugging in a telephone connection and using the appropriate power supply? Is there programming that...
Yes, there is programming which would need to be removed. However, you would need a cisco call manager($800) at home. Unless of course you have voip in your home. then you could just set it to DHCP I'm assuming and then it should just work!
Jan 14, 2010 | Cisco 7940 IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Cisco ASA 5505 Firmware
Yes, it is possible and Yes you have to purchase it from Cisco.
Sorry, that is how they make the big bucks.
Consider a service contract on the unit, then you can download the firmware much cheaper.
Jul 10, 2009 | Cisco ASA 5500 Firewall
Firmware
The firmware has corrupted.
Run the Philips Device Manager, installed from the driver CD.
Connect the PSS110 to the mains and PC, when the Philips Device Manager registers that the device is connected click on the Restore option, and follow the on-screen prompts.
This will format the device and replace the corrupted firmware.
NOTE: ANY TRACKS WILL BE DELETED
Apr 25, 2009 | Philips PSS110/17 MP3 Player
Method 1:
1) Unplug the phone
is a second method.
Method 2
  1. Press Settings.
Also see this link
May 18, 2008 | Cisco 7910 IP Phone
Cisco 7912g sip firmware
Jan 02, 2008 | Cisco 7912G IP Phone
Cisco ATA 187 Analog Telephone Adaptor ATA187-I1-A= Logo
841 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
