Question about Delta BS100 Shopmaster 9 Inch Bench Top Band Saw
How much should i tighten the belt after replacing with an 1/8th inch blade?
  • 604 Answers
I'm not sure about your question, but generally speaking any belt should have no more than 1/4 in movement up or down when pressed on, the same hold true for the band saw blade and in fat 1/4 would be too much, more like 1/8 in play
Posted on Mar 23, 2011
How do I TIGHTEN ENGAGE BLADE ON CRAFTSMAN RIDING 46 INCH
you can not tighten you need the right belt are your cable is to long because it going to brake
May 13, 2018 | Craftsman Garden
54 inch deck, mower blade belt too loose. No way to tighten it further so blades won't operate.
Check if tensioner is rusty, if bolt to tight, if that's ok replace belt with smaller size
Mar 26, 2017 | Garden
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The lever that operates the momer does not work. When I say it does not work, it does not let the mower start if not in the right position. But it does not disengage the momer blades so the engine will...
Remove and clean then replace the entire assembly that tightens the belt when you engage the blade.It should have a spring clean the spring with WD-40.This will allow it to release completely,and not spin the blades.
May 11, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
The powersteering belt has gone out, how do I replace it without taking it to the shop?
You will need some wrenchs, usually 1/2 inch and 9/16 or the metric equivalents 13 and 15 and something to pry with, a long screwdriver or wheel wrench,something flat and long.
Before you start look at the bottom pulley on your engine and note which groove is for which belt, they have to go back on the proper groove.
The alternator is probably the first belt from the rad, so loosen the bolt on the top of it and the one on the bottom, which you may be able to see but will probably have to feel out. Just a couple turns so it will loosen and you can remove the belt. You will have to feed it off over the fan one blade at a time. The second groove is probably the power steering.
On the back of the power steering pump you will see a bracket with a slot in it and a bolt. Loosen that bolt 3 or 4 turns. On the front of the pump there are 2 bolts to be loosened, 1 on top at the engine and one on the bottom about 7 o'clock. It will be hard to spot but feel around. Push the pump into the engine and start to feed the new belt over the fan, one blade at a time and slip it on the pulleys. Look at it from the side of the car and make sure the belt is lined up with itself to and bottom, it should be perfectly in line with itself.If not change pulleys until it is. use the pry, making sure it is on metal and not the plastic tank and snug the belt up. Tighten the back bolt first, and check the belt for tension, it should flex about 1/2 inch. Tighten the other two bolts on the pump.
Replace the alternator belt the same way, tightening the top bolt first. If ,by chance, you strip this bolt it's no big deal. Just get a longer bolt, same size that you can put a nut on and tighten it. Check for flex, 1/2 inch and tighten the bottom bolt.
Start the car once you have everything tightened up and turn your steering wheel lock to lock. If it turns hard or squeals, the belt needs to be tighter. Also check your charging light or guage to see that the car is charging. If not then tighten the alternator belt some more.
Don't be surprised if the power stering needs to be tightened in a while down the road, belts stretch over time.
If you have to remove an AC belt the tightening bolt should be at the back of the compressor, same as the power steering. Hope this helps.
Aug 18, 2009 | 1994 Cadillac DeVille
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
Mower drive belt comes off murray 17hp
if you look somwhere next to drive belt then there is a spring. you may have to tighten it. or bend the guiders on the pulleys that the drive belt goes through.
Apr 13, 2009 | Oregon Scientific Oregon Gator Mulcher...
Delta BS100 Shopmaster 9 Inch Bench Top Band Saw Logo
52 people viewed this question
Top Delta Saws Experts
Craig Butler
Craig Butler
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
