Question about Craftsman Garden
I need to know how the clutch works as I believe it is broke. The engine is an EZ fire 25cc craftsman on my weedeater/cultavator.
    Problem Solver:
  • 14 Answers
The clutch is centrifugal, if the clutch is broken it will most likely be hung up and not disengage making it difficult to pull the rope. Please let me know the model number xxx.xxxxxx and more about the symptoms.
Posted on Mar 23, 2011
Testimonial: "Thank you for your help. I believe that the part that engages the housing is missing. I think it got blown away when it blew up and came apart. I have"
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
I have a craftsman 25cc straight shaft weedeater.I believe the muffler is clogged.I cannot get the muffler off because I can't get the plastic cover off surrounding the engine.Can someone tell me how...
Torx head screws are down inside the cover. Some people call them "star" screws. With the proper size Torx head screwdriver (T-15 or T-20 I think), you will be able to unscrew the cover.
Sep 05, 2011 | Craftsman 25cc Gas Line Trimmer
How do I take apart craftman 25cc gas weedeater to replace the string?
Same problem here......need to replace the trimmer string......some of you guys and probably some ladies know this...Ple Don't know which way to turn the head to get it off, or if I also need a tool to remove it. Please help!
Aug 21, 2011 | Craftsman 25cc Gas Line Trimmer
I need to remove the clutch assembly from the shaft. Is there a special tool or technique I need to know about?
You will need to remove the bolt from the centre of the centrafugal clutch and remove it from the shaft with a flywheel puller. Good luck!
Aug 11, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
How to replace clutch on weedeater
The metal cover over the clutch is held on with a screw in the center. It takes a #15 or 20 TORX screwdriver. Once that is off you will see which way to take off the clutch. Good luck...Lee
May 30, 2010 | Craftsman Convertible 25cc. Gas Line...
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
My gas Craftsman Ez Fire 25cc 17 inch weed eater wont start!
The carb must be cleaned. take the carb off put it on a work bench and pull it apart layer by layer... be careful as there is a spring that will jump out. pull all of the gaskets off and clean behind them. make sure all of the passages are clean. Use brake cleaner from the auto parts store! do not use carb and choke cleaner as the gaskets will instantly expand and be useless. there is also a brass cylinder in the carb you need to remove it and clean it well. There should be a very small hole in the center. put it back together and you should be good to go
Jun 13, 2009 | Craftsman 25cc Gas Line Trimmer
Broken pull cord
You have to take four allen screw out of the plastic that holds the engine on. There is also one by the spark plug that needs to come out. Once the engine is loose, you have to unplug one wire and unscrew the other. Then the engine should come off. Then loosen the two allen screws holding the pulley in and it will come out.
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
480 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
