Tried to install hdtv usb receiver disk onto windows xp. Keeps telling me to install hotfix. What does that mean?
  • 1 more comment
  • yarny-triand Sep 09, 2008
    Yes I have had the same problem. Where do I find a "hotfix" solution??
  • agestones Apr 28, 2009
    yes i have the exact same problem!
  • WolfSpirit2 May 11, 2009
    Chyeah exact same prob.. havn't found anything to fix it yet..
Ok, I've got it sorted now. The driver that came with the TV stick doesn't like XP SP3.
I found this out there on the internet - not on the supplier web site though:
http://www.augustint.com/download.htm
This version of the driver likes XP SP3
http://www.augustint.com/download/AF...r-8.6.24.1.exe
Posted on May 11, 2009
Slipstream post XP sp3 updates
The same way you slip streamed SP3. You can download all the updates here. http://catalog.update.microsoft.com Alternately you update your system to a base install get all the updates and create a ghost image.
May 11, 2013 | Microsoft Windows XP Home Edition
Tip
Download all the SP3 hotfixes and Slipstream them to your CD
If you use Internet download manager IDM the fastest on the net cost $24.95
http://www.internetdownloadmanager.com
Import this ef2 IDM queue and it will do all the rest for you this is correct upto April 2009 feel free to add the missing 8 months worth I will update this when I have time
http://depositfiles.com/files/vtyqigsq8
If you want to install all the latest hofixes and security updates you can use Ross Smith's http://smithii.com/slipstream_xpsp3 command files last updated in May 2009, I use the xpsp3.cmd file to create slipstreamed windows boot CD for my friends. If you don't want to use them they are great to find out what updates and hotfixes can be slipstreamed.
Build a Bootable Windows XP disk with Service Pack 3 and all critical post-SP3 hotfixes slipstreamed
http://smithii.com/files/xpsp3.cmd
OR
Apply Windows XP Service Pack 3 and all critical post-SP3 hotfixes
http://smithii.com/files/xpsp3local.cmd
AND
To slipstream the hotfixes, and burn the slipstreamed disk
http://smithii.com/files/xpsp3.mak
N.B> This guy Paul Thurrott is also on Twitter and explains how to do this the old fashioned manual way although he is pre-occupied with Windows 7 at the moment.http://www.winsupersite.com
on Jan 07, 2010 | Microsoft Windows XP Professional for PC
2Gb Micro sd card not recognized by xp pc.
From Microsoft support:
Some Secure Digital (SD) cards do not work correctly on Windows XP-based computers. Additionally, you may notice a yellow exclamation mark (!) next to the SD card in Device Manager.
This problem may occur even though you have applied other hotfixes that are required for high-capacity SD card support. For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 923293 The 923293 hotfix adds support for SD High Capacity memory cards in Windows XP 934428 Hotfix for Windows XP that adds support for SDHC cards that have a capacity of more than 4 GB
Apr 15, 2010 | Kingston 2GB Secure Digital Memory Card
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Apr 03, 2010 | SanDisk Sansa Clip MP3 Player
Code 28 i already downloaded the hotfix from microsoft
Just run windows update which will tell you that new updates are ready to be installed. Click O.K. Re-boot when asked & your done.
Sep 03, 2009 | Microsoft Windows XP Professional
Install Windows xp off USB
If you are only trying to boot to windows then you'll need files NTLDR, Boot.ini, NTDETECT.COM, and NTOSKRNL.EXE on the USB drive. This will boot you to the windows screen. Trick is to get those files off of your windows CD onto your USB...then copy those over to the c:\ and that should also take care of boot problems if it was because of corrupted files.
Apr 04, 2009 | Dell XPS M1530 Laptop
XP installation - CISIF.DLL is not a valid windows image
I DONT HAVE THE SOFTWARE FOR THE DRIVE FAX -L350
SO I NEED THE FREE SOFTWARE FOR THIS DRIVE
AND I WANT TO DOWNLOAD IT NOW
Dec 09, 2008 | Canon FAX-L350 Plain Paper Laser
Creative Zen Microphoto Code 10 on Windows Vista
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
Feb 04, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Usb compatibility with windows xp service pack 2
Install the service pack 2 and update via Windows Update!(Go to Tools then Windows Update in Internet Explorer) Install the USB Wireless Adapter! Follow the procedures here! http://support.dlink.com/faq/view.asp?prod_id=1398&question=DWA-130%20/%20DGL-3420%20/%20DWL-AG132%20/%20DWL-AG530%20/%20DIR-330%20/%20DWL-AG660%20/%20DWL-G120%20/%20DWL-G122%20/%20DWL-G132%20/%20DWL-G510%20/%20DWL-G520%20/%20DWL-G520M%20/%20DWL-G550%20/%20DWL-G630%20/%20DWL-G650%20/%20DWL-G650M%20/%20DWL-G680%20/%20DWL-G710%20/%20DWL-G820%20/%20WDA-1320%20/%20WDA-2320%20/%20WNA-1330%20/%20WNA-2330%20/%20WUA-1340%20/%20WUA-2340%20/%20DWL-P100%20/%20DWL-P200%20/%20DWL-P50%20/%20DWA-142%20/%20DWA-542%20/%20DWA-552%20/%20DWA-556%20/DWA-642%20/%20DWA-643%20/%20DWA-645%20/%20DWA-652%20/%20DWL-M60AT%20/%20DWL-R60AT%20/%20DVG-G1402S%20/%20WBR-1310%20/%20WBR-2310#sp2 Now try the connection! If you still have problems, let me know! regards, babb
May 04, 2007 | D-Link : DWL-AG132 a/g Wireless 108M USB...
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
