I'm trying to enter my activation code and the program won't let me enter any '0's or '1's. It's not a problem with my keyboard since obviously I just typed them in a different program.
  • 83 Answers
You could try typing it in something else (notepad, wordpad, email) and then copying and pasting it into the activation code area.
Posted on Mar 23, 2011
  • caroljantsch Mar 23, 2011
    I tried that, didn't work either.
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 08, 2012 | Computers & Internet
I have forgotten my alarm code for my motorhome Sigma S30 The keypads still work but I need the code to reprogramme a more rememberable number
Here are some important informationabout Sigma S30. Programming a New PIN Code:
The standard PIN code can be changed following thesequence below:
i) Type in to the keypad **
ii) Type in to the keypad the "existing PIN code" then *
iii) Type in to the keypad 92 * "new PIN code" * "new PINcode" #
Programming Remote Keys to the System:
Remote keys can be added or removed to/from the systemfollowing the sequence below:
iii) Type in to the keypad 91 * " the number of keys to beused" #
iv) Press the first remote key button until bleep sounds,release and press next key. Continue until all
keys have been taught to the system. Note the maximumnumber of keys is 4 and all keys required
to operate the system must be taught during this operation- any key not included will no longer
operate the system.
Full Programming, Diagnostics and Features
This section contains all the information that the dealersuse for programming and diagnosis of
the Sigma M30 alarm system, using the MK1 keypadprogrammer.. Programming can also be carried
out using a dealers CP1 programmer.
MK1 Keypad Programming Introduction
It is important the keypad buttons are not pressed tooquickly-
Each time a button is pressed the LED on the keypad willflash once as confirmation. The next button should
not be pressed before this confirmation.
It is important the keypad buttons are not pressed tooslowly-
When in programming mode, if a button is not pressed for aperiod of 10 seconds or more, the alarm will
automatically exit programming mode. This will be confirmedby repeated flashes from LED on the keypad.
You must wait until the LED stops flashing and then startagain.
All programming functions are entered after typing * andthen the programming PIN code. The programming
PIN code is 17856.
To enter the programming PIN code, the alarm system mustfirst be armed and then disarmed using a valid
remote key. (Or keypad using the PIN code)
* 17856 * must then be entered within 30 seconds ofdisarming the system. This is then followed by a 2
digit function code, then another * and then sometimesoptional parameters as shown in the following tables.
It is important to remember the * key is used to separatethe various parts of the code like this:
* programming PIN code * function code * parameter #. The# key is pressed at the end of all
sequences and is used like the "enter" key on a computer keyboard.
Programming Features On or Off:
Programming
PIN
Function
Code
Switch Code
(where 0=off and 1=on)
Function Default
* 17856 * 00 * 0 or * 1 then # arm/disarm bleeps * 0 (off)
* 17856 * 01 * 0 or * 1 then # door open warning bleeps *0 (off)
* 17856 * 02 * 0 or * 1 then # auto-lock * 0 (off)
* 17856 * 03 * 0 or * 1 then # auto-arm * 0 (off)
* 17856 * 04 * 0 or * 1 then # auto-arm to include doorlocking * 0 (off)
* 17856 * 05 * 0 or * 1 then # auto-rearm * 0 (off)
* 17856 * 06 * 0 or * 1 then # engineer mode * 0 (off)
* 17856 * 07 * 0 or * 1 then # hold-down remote key button= -ve
output on wire 4
* 0 (off)
* 17856 * 08 * 0 or * 1 then #
hold-down remote key button =
extends lock pulse
* 0 (off)
* 17856 * 09 * 0 or * 1 then # after disarm -ve output onwire 4 * 0 (off)
Programming Timing Settings:
Programming
PIN
Function
Code
Variable(s) Function Default
* 17856 * 10 * 1 to * 30 then # stall to ignition on timein seconds 30 sec
* 17856 * 11 * 1 to * 99 then # unset to ignition on timein seconds 30 sec
* 17856 * 12 * 1 to * 99 then # panic time in seconds 05sec
* 17856 * 13 * 1 to * 51 then # lock time in seconds (51gives two
short pulses)
01 sec
* 17856 * 14 * 1 to * 51 then # unlock time in seconds (51gives
two short pulses)
01 sec
* 17856 * 15 * 1 to * 99 then # settle time in seconds 15sec
* 17856 * 16 * 1 to * 99 then # threshold setting time inseconds 15 sec
* 17856 * 17 * 1 to * 99 then # auto arm time in seconds60 sec
* 17856 * 18 * 1 to * 99 then # auto re-arm time and also-ve
output time after disarm , on wire 4
(green/red) in seconds
60 sec
Displaying System Diagnostics:
The dashboard LED displays the value of settings as anumber of flashes.
Programming
PIN
Function Code Function
* 17856 * 30 then # time elapsed since last trigger (inminutes)
* 17856 * 31 then # as * 30 above - but each flash = 256minutes
* 17856 * 33 then # wire 7 (orange) ignition trigger count
* 17856 * 34 then # wire 1 (blue) -ve door trigger count
* 17856 * 35 then # wire 2 (blue/red) -ve boot triggercount
* 17856 * 36 then # -ve bonnet switch trigger count (blacksingle wire on siren
plug)
* 17856 * 37 then # ultrasonic's trigger count
* 17856 * 38 then # last trigger register (see tablebelow)
* 17856 * 39 then # reset all above trigger counts to 0(zero)
Setting Up Pre-set Programs:
Keying in the following sequences on the keypad sets up afixed set of features, which can be used as a
starting point for further tailoring:
* 17856 * 80 # everything off, lock and unlock pulses 1second.
* 17856 * 81 # as for * 80 above, with auto-rearm on.
* 17856 * 82 # as for * 80 above, with auto-arm on.
* 17856 * 83 # as for * 80 above, with auto-rearm andauto-arm on.
* 17856 * 80 # Default setting configures the values shownin the previous tables 1, 2 and 3. Hope this will help you. Good Luck.
Aug 22, 2011 | GPS
When I try to type the numbers of the card required for product activation (Rosetta Stone-Hebrew level 1) , the keyboard does not type some numbers and some letters.
The activation code that you're trying to enter is on the back of the card. You have to remove the card from the packaging and then scratch off the silver stripe. You'll find that the activation code contains no 0's or 1's.
May 22, 2011 | Computers & Internet
Keyboard key not typing primary character, shift/fn strokes work
this is to do with your FN key....it is activated to be on all the time...
googlesearch this ...
Sep 15, 2009 | Dell Inspiron 1521 Notebook
HOW TO OPEN THE DOOR USING THE NUMBER PAD ON THE DOOR
this from the owners manual
Programming your own personal entry code
To program your own code:
1. Enter factory set code (keypad will illuminate when pressed).
2. Press 1/2 control within five
seconds of step 1.
3. Enter your personal 5 digit code.
Enter each digit within five seconds
of previous one.
Do not set a code that includes five
of the same number or presents
them in sequential order. Thieves
can easily figure out these types of codes.
Your personal code does not replace the permanent code that the
dealership gave you. You can use either code to unlock your vehicle. If a
second personal code is entered, the module will erase it in favor of the
new code.
If you wish to erase your personal code, use the following instructions:
1. Enter factory set code.
1 2 3 4 5 6 7 8 9 0
Controls and features
90
seconds of step one.
3. Press 7/8 control and 9/0 control
at the same time within five seconds
of step 2.
The system will now only respond
to the factory set code.
Unlocking the doors with the keyless entry system
To unlock the driver door, enter either the factory set code or the
personal code (each digit must be pressed within five seconds of the
prior digit). The interior lamps will also illuminate.
To unlock all doors, enter the factory set code or personal code (driver
door unlocks) and press the 3/4 control within five seconds.
Locking the doors with the keyless entry system
It is not necessary to enter the factory or personal code prior to locking
all doors. To lock the doors:
² Press the 7/8 control and the 9/0 control at the same time.
Activating/deactivating
May 19, 2009 | 2000 Ford Expedition
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Key board problem
It sounds like you have Num Lock activated. Turn that off and it should go back to normal.
On my Dell laptop I have to use a Function + F4 key combination to do this. It'll probably be a slightly different key combination on your machine, but the same idea (assuming you don't have a dedicated Num Lock key).
Dec 30, 2008 | Compaq Keyboard
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Computers & Internet Logo
318 people viewed this question
David Payne
David Payne
