Question about PSC Falcon 4420 Barcode Scanner
What size of sd card does the psc falcon 4220 scanner take
My pandigital scanner is missing the SD card. I bought a new SD card by SanDisk. It is a 16gb and does not work with the scanner. Is there only a certain type that works with the scanner?
Well, there are different types of SD sizes.
If you believe you've got the right size and you have only one slot for SD, as if you have different types they might interfere with each other and things could get saved only on the one that is dominant, then you should check your model's manual and which SD cards it supports. My other suggestion is that you try the card on something else if everything else seems in check and see if you didn't get a faulty card.
I did find this manual and it seems like SanDisk isn't in the list, but for your model it could be different.
http://static.highspeedbackbone.net/pdf/Pandigital-PANSCN02-Photolink-Scanner-Manual.pdf
Jun 26, 2017 | PANDIGITAL Cameras
If the touch screen wont light up on a falcon 4220 does that mean the touch screen itself is bad?
THE TOUCHSCREEN/DIGITIZER IS A DIFFERENT PART FROM THE ACTUAL SCREEN , YOU JUST HAVE A BAD SCREEN .DIGITIZER IS GOOD .
HOPE THIS HELPS ,IF NOT I CAN HELP YOU MORE
Nov 19, 2014 | Datalogic PSC Falcon 4220 Data collection...
Can you scan a paper straight to a sd card.
yes you can just open the scanner setting and set the image saving destination to you sd card drive.thats all.
Jan 06, 2011 | HP PSC 1350 All-In-One Thermal Printer
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Pinout rs232 I want to print directly form handheld falcon 310 using rj45 jack
The pinout for that type of device is most likely in the yost format. It is a standard used with most pos equipment. You can get a diagram here : http://www.lammertbies.nl/comm/cable/yost-serial-rj45.html
Hope this helps
Jay
Jun 29, 2009 | PSC Falcon 310 Portable Terminal
FALCON 320 SHUTS DOWN
try to read your manual.. it might help you..
Jul 29, 2008 | Computers & Internet
SD memory card
What format are your photos?
Mar 15, 2008 | Electronics - Others
PSC Falcon 4420 Barcode Scanner Logo
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
