Question about Toro Garden
Toro model 55620...The HMR will run forward and also in reverse, but when I turn the wheels to the left or right, it stops pulling...any suggestions
SOURCE: Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Posted on Oct 14, 2008
wadembly
  • 513 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
wadembly
  • 513 Answers
SOURCE: I have a toro hmr 1200 and one rear tire drives one won't
some of them has a key that helps both tires spin but alot of riding mowers have only one tire spin but not all it could be in the gears it's self
  • 5 Answers
SOURCE: I replaced the rear right wheel on my craftsman
retrace your steps
Posted on Jul 27, 2009
  • 95 Answers
SOURCE: craftsman model 917.271814 will not go forward or
Check the drive belt that runs back to the transaxle,it sounds like it broke.If the belt is in the pulley check to see if the transaxle pulley is turning when the clutch is out.Also make sure both wheel axle keys are in the rear wheels.If all this checks out the transaxle may have broke,look underneath to see if it is broken there.
Posted on Aug 06, 2009
Why won't the wheels move forward or backward on my Toro 54" Zero Turn Lawnmower. Was mowing and it stopped moving.
usually if the pins are pulled out that is the freewheel position. push them in to drive. if the trans locks in drive and it is hard to push it should be ready to mow. unless the drive belt is stretched or broken or a linkage is out of adjustment or broken.
Jun 01, 2018 | Toro Garden
My toro groundsmaster stop running when you push on the pedal forward or reverse
Here's the link,select your model and you will find the answer.
toro
Sep 06, 2017 | Toro Garden
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
Wheels are locked when trying to push it forward with engine shut off.
There should be a release to disengage the drive system so you can push it when not running. On my Cub Cadet it is on the back above the hitch. It is a simple lever that I pull out and push up to disengage. Has to be something similar on the toro.
May 02, 2016 | Toro Lawn Mower. 22 in. Personal Pace with...
Z model. Won't steer to the right, reverse or move forward. What's wrong?
Sounds like you have a broken shear pin in either your wheels or in your drive pulleys See if you can reach up where the drive pulleys are and try to turn them by hand. If they turn but not the wheels then you know you have a broken shear pin. Do not try to run the engine and do this for safety reasons.
Jun 13, 2015 | Toro Garden
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
