Question about Whirlpool Washing Machines
When washing clothes once my washer gets to the spin cycle it starts slaming and banging loudly and my clothes are completly soaked, instead of damp
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the balance it is possible that the internal suspension is malfunctioning.
I also recommend checking the filter in case water is being left inside the washer at the end of the spin.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Good luck,
John C
Posted on Mar 23, 2011
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My frigidaire 417 front loading washer drum bangs around violently especially during "spin" cycle. What can I do to remedy problem?
You never want to over load your machine, when you do some of the heavier clothes seem to go to one side of the machine. When the spin cycle starts and it's making that loud sound, open it up, wait for the spin to come to a complete stop, then make sure clothes are evenly around. Then put the lid back down it should be fine then. If it's not, then repeat above steps. I hope this helps. Thank You for using FixYa.
Jan 05, 2011 | Frigidaire ATF6000ES Front Load Washer
My washer is making a clicking sound when it is about to begin the high spin cycle to spin the water out of the clothes and is unable to begin the spin cycle on it's own. I have to manually move the knob...
If this is a belt drive unit it could be the belt or whats called a actuator also call a shifter. This componet switches the gearbox from agitate during wash to Spin to extract the water from the garments.
Happy Holidays
Nov 21, 2017 | Whirlpool LSQ9500L Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
GE Profile - Loud knocking on spin cycle
Just random input, I apologize if this is of no help to you. I've only experienced this with my washer when clothes somehow get bunched up on one side of it.  The best I can tell you at the moment is to make sure there is relatively equal distribution of clothes around the "washer bucket thingy" if you hear the bang bang bang again.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washing Machines Logo
22 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
