Question about Maytag Dishwashers
Will not let the water run in - Maytag Dishwashers
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 23, 2011
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
Machine runs and mixes. Compressor seems to run but mix will not thicken. Seems like mix is not getting cold enough. A water cooled unit.. Tried to bypass water intake switch so water was always...
if its a water cooled unit when the compressor is running water should be running thru the valve, if it isn't be sure you have the water correctly hooked up and its cold water, if it is and still no water you have a bad valve
Apr 03, 2011 | Taylor 632-27 Ice Cream Maker
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Water is not running through
Replace your water sensor. If it runs out of water you can pop the water sensor and it will not allow any water to pass through due to the fact that it sends power to the water inlet valve and that is how you get water to flow and not flow into your system
Feb 22, 2009 | FrancisFrancis! X5 Espresso Machine
Water doesn't run in to clean dishes
if the water line not blocked or pinched... then I would your fill valve.. it may not open all the way...before replaceing the water valve...check that the water is come into the dishwasher but maybe going out the drain..If the drain hose is too low water will run out before the dishwasher can run a cycle... to check it it must raise above the bottom of the sink ... this keeps water from running out and sink water from going into the dishwasher... let me know if it helps
Jan 29, 2009 | GE 24 in. PDW7880JSS Built-in Dishwasher
WFK 2401
Replace hot water valve.
Aug 13, 2008 | Bosch WFK 2401
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
