Question about Dryers
How to install gas dryer? - Dryers
    Sniper:
  • 68 Answers
A gas dryer uses 120V.
You must have a gas supply with a minimum of a 1/2" x 36" flex. This allows for your dryer to have enough gas to operate.
You must have a dryer vent that is not vinyl. The gas dryer gets hotter than the electric and will melt the vinyl vent.
Please rate this solurion
Posted on Aug 03, 2008
How do I install an igniter on a G. E. gas dryer?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | GE DBSR453GBWW Gas Dryer
Tip
Choosing a dryer.Gas or Electric
A gas dryer saves electricity cost, but requires an installed gas line to the home and special installation. If gas is available for a dryer, the outlay for a gas dryer model may be a good option if your dryer usage is high. An electric dryer costs less, but requires installation and energy costs for a dryer varies with usage. Both types of dryers require proper venting to the outside. Always follow the dryer manufacturer's installation recommendations.
on Aug 17, 2010 | Refrigerators
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
I just installed a used gas dryer
yes,you will need to find the right gas orfices for propane vs. natural because of the pressure difference,they do have kits for this,but consult the gas supplier for added advice
Jan 25, 2010 | Dryers
There is no heat. Just installed a new dryer and
gas may be connected but is there gas there ! make sure gas is present in the line.. ck that dryer is not on air fluff .. if it still does not heat and dryer has been moved . like one house to another ./ a good bang ( drop) may have damaged ignitor .. if so replace ignitor . mm
Dec 03, 2009 | Refrigerators
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
LP gas supply tank is empty or there has been
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
Natural gas smell
then checkout the tubing that goes to the burners and pilot flame tubing too,
Jan 11, 2009 | GE DBVH512GFWW Dryer
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
Install 220 outlet for electric dryer or trade it for gas dryer?
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Sep 13, 2008 | Kenmore 63942 Dryer
Dryers Logo
174 people viewed this question
Top Dryers Experts
