Question about Fisher and Paykel Washing Machines
I have a MW051-U washing machine Istarted a load of washing then the machine stopped with the unbalanced beeps, I took out the towels then placed them back in, but now washing machine wont start up again. I have turned in on and off powers up fine buttons work fine but nothing happens when I hit the start button
    Brigadier General:
  • 6,277 Answers
Start by balancing the machine.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If powering off, leaving for 30 minutes then on again does not clear, a manual should help as I'm not 100% sure of another way and a manual could help for problems in the future.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 23, 2011
My GE washer/dryer all-in-ne is very loud and keeps getting unbalanced
yes it depends on the size of the towels , try doing only 5
Jan 21, 2015 | GE Washing Machines
Hotpoint top load unbalanced
Darla heavy objects such as towels and jeans not evenly distributed in the washer will cause this to occur, open lid let washer come to a stop and then reposition clothes
If it is unbalanced as in the whole machine rocks even when not running then the rear levelers are out of position, pull top of washer towards you tilting the whole machine, towards you, the rear levelers will self adjust unless jammed, you may need help tilting the unit
Jul 09, 2012 | Hotpoint VVSR1070D Top Load Washer
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle tub becomes unbalance
When the drum gets unbalanced more often then not, there's a few things to check:
1. Check to make sure your machine is level. Check level from side to side and also front to back. The machine has leveling feet to adjust. Make sure they are all in firm contact with the floor when leveled.
2. Wash items that are alike in material. In other words, wash towels with towels, shirts with shirts, etc. If you wash a load of shirts with a towel, it will have a tendency to get unbalanced quickly.
3. Avoid over-stuffing the machine and washing under sized loads. Both of these scenarios will cause a tendency to go out of balance on the spin.
This will solve 75-80% of unbalance issues. Let me know how it goes..
Dec 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Our washing machine was stopping at various stages & would beep and just not continue with the cycle. (Sometimes it would fun a full cycle without a problem however). We took it to an official...
The drum suspension rods may be worn or one of them may be brocken, throwing the drum out of balance.
They are fairly easy to change if you know how to open the top hatch. Check and remove them individually.
Let me know if you need assistance or more info.
Ash
Oct 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
During spin cycle it becomes unbalanced and it beeps and stops
It sounds like the sensing arm of the out of balance switch assembly is wrongly set. Get the guy back to do the job properly at no charge!
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Nov 08, 2007 | Washing Machines
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
