My asus k60ij won't boot up when i press the power button
  • mikedog_robe Mar 24, 2011
    that kinda helps but it tries to startup but the screen wont come on
  • 368 Answers
Glad to HELP YOU!
If your machine doesn't boot by pressing the POWER button it means that your computer doesn't have power to start up.
So probably the Power Supply Unit/Power Unit is defective and it has to be replaced.
If you are computer savvy you might check it and you might replace it by yourself. But if you are not ask the help of a technician. These Asus machines are sometimes very fragile and easy to be broken.
Hope it helps you!
Posted on Mar 23, 2011
How to enter Asus Q534UX BIOS
Windows 10 - How to enter BIOS configuration? - Asus
https://www.asus.com/support/faq/1013015/
  1. Cached
  2. Similar
Hold and press [Shift] then turn off the system. Press and hold the F2 button then click the power button. DO NOT RELEASE the F2 button until the BIOS screen display. You can find the BIOS configuration. Category. Windows 10 - How to enter BIOS configuration? Windows 10 - How to boot the system from USB drive/CD-ROM?
How to enter Asus Q534UX BIOS Google Search
Jan 26, 2017 | ASUS Computers & Internet
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
I cant reset asus rt-n10e routr
I had same problem with my asus device. so i called Asus Tech Support At Toll Free Number 1800-585-2494 and they have fixed my problem.
Hope they will help you as well.
Jan 20, 2013 | ASUS WIRELESS ROUTER |WL-520G - RT...
I need the user manual for the k601j. thank you.The user manual waas not part of the purchase.
Hello.
Most laptops don't have a manual, because they are all same.
Instructions to use Windows 7 can be found online on Microsoft's website.
Aug 23, 2011 | ASUS Computers & Internet
How do lock my laptop mouse pad on my ASUS Notebook K60IJ?
you have a small button on either the left or right side of your power button. It will be orange if it is disabled. Press the button once and you should then be able to use your mouse.
Please leave rating and/or feedback if you found this helpful
Thanks!
Nov 10, 2010 | ASUS Notebook
How do i get my Asus k60ij camera to work
There is a program that should be installed on your computer called ASUS LifeFrame. Its located under ASUS Utilities which is under "All Programs"
Oct 02, 2010 | ASUS Computers & Internet
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
I have a Asus K60ij laptop and I cannot eject my
If when you press the card in to eject it, it doesn't come out, you can use a pair of tweesers to gently pull the card out. There are no mechinisims holding it in place.
Nov 22, 2009 | ASUS A6U Notebook
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
Computers & Internet Logo
548 people viewed this question
David Payne
David Payne
