Question about Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White
Water will not go into tray, if i fill it manualy it will dump--can you help--whirlpool gs5shaxnq00
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Your water inlet valve will likely need to be replaced. It is on the back of the refrig where the water line hooks to it. The link below will take you to it....
Water Inlet Valve $40.89
Kelly
Posted on Mar 23, 2011
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
My ice maker quit, was replaced with a new one, it filled and dumped one time, filled again, didn't dump, was thawed out then didn't fill at all. Water still dispenses from the door just fine.
If the unit is new return it for another one - if there is water in the tray and it is not dumping, either the unit is not working properly or the internal freezer temperature is not going down low enough for the unit to work. Has to go down to at least 10 degrees for the tray thermostat to start the ice dump/making cycle.
Nov 28, 2013 | Whirlpool Refrigerators
My Whirlpool is not making ice cubes and the tray is dry, no water inside the ice maker but the water dispenser is working fine.
Most likely the water control valve on the rear of the refrigerator is defective on the ice maker side. Fill the ice maker with tap water and if it dumps the ice and does not refill then the water control valve is the reason. Usually an ice maker that still had cubes and will not dump the problem would be the ice maker. Hope that helped you, Thanks, Sea Breeze
Nov 22, 2009 | Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirlpool Side by Side Bad Water Taste
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
hope that helps.
good luck
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker
did you find out how to fix it ? please let me know
Jul 06, 2008 | LG LRSC-26922 Side by Side Refrigerator
Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
