Hi There, We are in a rental property and have a bosch 21e hot water system. We haven't been getting hot water and the gas bottles have been checked and are full. Do we have to light the pilot and are there specific instructions we need to do this. Wanted to check all possible solutions before reporting it to the rental property real estate. As always with rentals there are no instruction manuals left for us to work it out. Kind Regards Janice
    President:
  • 1,654 Answers
You may have a dirty pilot orifice. Try this. Turn off the pilot by turning the control knob to off. Remove the front panel to get access to the pilot orifice. Use a can of compressed air with attached straw (the same stuff you use to clean computer keyboards) and blow out the pilot orifice, which is inside the pilot assembly where the pilot flame burns. Blow it out from the top and from the sides through the air holes. Then relight the pilot and see if that improves the flame size and color (blue) to heat the thermocouple.
Here is a link to the manual and instructions. www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125B_manual.pdf
Posted on Mar 23, 2011
We have a gas unit in our ensuite for a hot water we can not seem to get any hot water the gas cylinders are getting low so i have asked for them to be refilled or could i there.
refill the gas bottles and then if that doesn't fix it, get a technician out as it may be the pressure switch not opening the gas so that the pilot light ignites the burner
May 03, 2015 | Bosch Water Heaters
We have had major blackouts does my bosch highflow 21e need to be reignited or automatic....how long should it be until I get hot water
you have to reignite it yourself turn dial to pilot and press down the light with either the internal igniter or a long match when lit then you turn dial to the ON position .
Apr 25, 2015 | Bosch Water Heaters
I have moved into a property with a kelvinator LPG
Most probably the flow switch that senses water flow and opens the gas and turns it on is stuck due to not being used.
Sep 18, 2014 | Water Heaters
Why is my Bosch high flow 21e heater started working intermittently only heating water after tap is turned on and off a few times
Check gas pressures first especially on low setting. Ensure gas burner is clean get unit serviced if over 2 years old. Check or replace water flow sensor & clean inlet filter.
Jul 26, 2014 | Bosch & Tankless LP Hot Water Heater
I have a bosch system 21e it is, i was told to ignite the pilot light, can you tell me how this is done?
Consult your owners manual.
http://www.bosch.com.au/content/language1/downloads/70R_UserManual1023.pdf
Heres a new one if you don't have or lost yours. You can't, you got bad advice. tankless system don't have a running pilot light. They operate by detecting water flow and then turning on. Many also state on the lighting instructions to NEVER try and manually light the pilot. Try Bosch tech support. Lowes sells Bosch heaters and they might be able to help you get the support number faster. Hope this helps but please don't go sticking a flame inside there.
May 16, 2011 | Bosch & Tankless LP Hot Water Heater
My bosh 21e hot water system truns itself off. the only way i can get hot water again is to unplug from power
Best I can offer is troubleshoot resources, including Bosch contact numbers and possible troubleshoot links and possible manual.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
And then you add a comment with solution that worked so others with same problem can read 1 possible answer for their identical problem.
Check back since people occasionally add a comment.
Solve most tankless problems yourself, same day, all brands for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | Bosch Water Heaters
How long does it take to reheat water when gas bottle runs out and then you switch to new bottle ?
water getting hot should be almost instant... it may take a minute to move the cold out of the pipes.
is your heater ignighting?
if not then you might have a small amount of air in the gas line when you changed the bottle.
you will need to bleed the line...
with the gas turned on, loosen the gas connection to the unit and let the air out until you smell gas.
tighten the connection, snug, do not over tighten.
wait about 5 minutes for the gas to dissipate before attempting to light the unit.
during this time, you can use a little soap water on the connection you loosened to make sure it is not leaking.
now go turn on your faucets, let the water run for a minute and make sure you get hot water.
if no hot water, then you might have something else wrong. you will need to let us know the error code and what the unit is doing
Aug 11, 2010 | Bosch & Tankless LP Hot Water Heater
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
Can't get hot water heater to work - Rinnai Infinity 18
If you can get to the gas valve make sure it is in the on position and not in pilot or off. Does it sound like
a spark ignition system? Even though you say the gas valve is on, by code thered should be a gas shutoff valve located within site of the unit. Follow the
gas pipe until you find such a valve and make sure its on
Feb 07, 2010 | Rinnai Vent Free Gas Heater/
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
