When ever I try to print on my Canon iP3000 I get this message - Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart.
  • 252 Answers
Jilar,
Is the front tray down? That is the document output tray and it will detect an error if it's not down.
Posted on Mar 23, 2011
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
Nov 04, 2011 | Canon Pixma iP4500 InkJet Printer
Canon Pixma i4300. Front output paper tray pounced on by pet cat. Closed it up and opened it again When I try to print I get this message: "Document printing cannot be executed because the paper...
If you can remove the tray - have a look at it and it should come out without much force by pressing on the sides. If it comes out you may see the sensor inside that maybe is bent up and is not registering that the tray is open. If you see it you can bend it back down. You can also shoot canned air(with the tray in the out position of removed from the machine) and a piece of debris may come out. Use short squirts or the can gets very cold. All the office supply places and computer stores sell the cans of compressed air.
If none of the above helps, you can always communicate directly with Cannon at:
http://usa.canon.com/cusa/office?pageKeyCode=contactUsLanding
I have found them to be very helpful. Good luck..............................Pete
Jul 20, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I have Canon pixma MX310 and I just trying to set it up.I'm trying to print and there is message open paper out tray.What is that mean and how I can fix it
The printer will not print as long as the paper output tray is closed.
  1. Open the Paper Output Tray (2).
    Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
  2. Open the Output Tray Extension (3).
    Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
  3. Adjust the position of the Paper Thickness Lever (4).
    Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper.
Oct 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Mar 23, 2009 | Canon Pixma iP4500 InkJet Printer
Printer Error
there is button or clip backside of the printer.......u just press it and open the tray..........it is also possible that u don't attch ur usb wire to the cpu u just check it .........may be it will be good........
Apr 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer door open message
Apparently a solution has already been posted here: http://www.fixya.com/support/t345435-ip4300canon_printer
The author provides instructions on opening the printer and gluing the sensor into the "open" position (assuming that the sensor still works).
Apr 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
362 people viewed this question
k24674
jasbo
jasbo
