Question about HP Laserjet M2727nf Multifunction Printer
How to scan picture bigger than normal size with HP Laserjet M2727?
  • HP Master
  • 1,915 Answers
You will need to launch the HP ScanWizard and then modify one of the preset scan settings. The software needs to be set so that the actual scan wizard software launches when you go to scan, not just scanning directly. This will give you the option to change resolution and output.
Posted on Mar 23, 2011
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Hp 3390 work with w7 64x in scan mode ???
Your 3390 will only scan by using the Windows scanning software, the HP solutions do not work on Windows 7.
This is how you can scan from your 3390, assuming you have been able to get it working for printing on your system.
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
I have an HP laserjet m2727 mfp series 4 in 1 multipurpose that can only print and recieve fax. What would be the problem? Please help me.
The detail isnt clear.
But if your machine doesnt do copies, scan or send faxes it would seem that ther is a problem with the scanner unit on your machine, Lift the ADF unit (as if you wer to do a copy from the glass) keep the lid open so you can see the scan unit, do a copy and check if the scanner unit moves and check if the bulb is burning.
These machines are notorius for dodgy formatter boards.
But i would start with checking the scanner unit.
Feb 18, 2011 | HP Laserjet M2727nf Multifunction Printer
Hp M2727 goes into low power sleep mode and can only recover by cycling power
You may need to have your printer's firmware updated by a certified technician.
Jun 08, 2010 | HP Laserjet M2727nf Multifunction Printer
The problem is I have a new M2727 and no operation manual. If there is one on this site, I can't find it. I would like to know how to get scans to my pc.
You can find manual as well as reference guides, installation cheatsheet and everything here
http://www.generalmanual.com/Printers/HP-LaserJet-M2727nf-MFP.htm
Except for the drivers; those you will find on the HP support web site. You'll have to specify the OS and connection type. For XP, Vista and 7, the easiest scanner driver is the WIA one; if you want full control on the scanner's operation, install the HP one.
Jun 07, 2010 | HP M2727NF Laserjet Printer
Scanner LaserJet M2727 Output default
You cannot fix this by modifying settings, contact hp tech support and have them take remote access of your computer, they need to replace a file which is causing the problem.
Hp tech support 1800 334 5144
Al
Mar 30, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet 3055 scans larger than print area
When you place a document for scan, you must select the portion you want to be scanned.
You must also set the resolution which is set to 300 by default, if you want a actual size then set the resolution to 75, which is 3% larger then actual image.
It will reduce size in KB or MB of your image and it will be exact size.
Similarly, when you want to print, you must select option "Exact Fit" and print your document.
Everything will be normal.
Cheers
Nov 06, 2009 | HP LaserJet 3055 All-In-One Printer
How to enlarge a picture when scanning on a HP F2210
The bigger you are going to want to print the final picture the higher the resolution you will want. So set it on the highest resolution then you will be able to make the picture however big you want in your photo-editing software.
Thanks,
Lee
Nov 05, 2009 | HP Deskjet F2210 InkJet Printer
HP PCL5c paper source options for HP M2727
you will find it here
http://www-01.ibm.com/support/docview.wss?uid=nas1ba0863cfa6463903862569c10078c903
HP LaserJet M2727nf MFP HP PCL5/PCL6 N hppcl5.pdt
HPLJ4.PDT *RICOHAP3200
*HP5SI
*HP4000 Y Y Y ? PostScript 3 emulation N n/a n/a
Jun 16, 2008 | Office Equipment & Supplies
HP Laserjet M2727nf Multifunction Printer Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
