Question about Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2
I have a Hydrfarm Green Thumb Light System with no instructions on how to set up the strings so that the light can be adjusted. How should the string be threaded?
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
There must be something simple I am doing wrong. On a D700 body, I can't seem to trip the shutter in any aperture other than f16.
I have a Nikon D60, and it has numerous settings, including aperture and shutter priority, and others. It sounds like you have have it set in aperture mode, set for f/16. First try taking a picture in dimmer light, where it's not so bright. That should cause the shutter to open longer. The camera will adjust the shutter speed to take the best picture at f/16 if it's set for that.To adjust it to something other than f/16, on my camera, you use the thumb wheel on the back of the camera. Try changing that if it has a thumb wheel.
Next try it in Auto mode by rotating the dial on the top of the camera to the green setting and see if you get a batter picture.
If all else fails, consult the camera manual, if you have one.
Jul 13, 2011 | Nikon 85/1.4 AFD Nikkor Lens
Hi, i have a acoustic guitar and i am trying to tune it but i do not know how to use the Matrix Chromatic Tuner SR-1050
Hi
Simply turn the tuner on using the power button. Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
Uh70015 dirt sensor stays on green. Goes on red for about 5 seconds then green. Can clearly see the floor is dirty and it is picking up stuff.
ahh the good ol electronics on vacuums selling the product again...
not to worry, your feature is working properly, your vacuum is working fine too.
Imagine if you will making a circle with your pointer finger and your thumb. Now put a string or thread across in a straight line there. The string would be the size of the beam of light that the sensor uses. Your finger and thumb are about the size of the tube that the dirt and dust is passing by. Unless the dirt passes and cuts through the beam of light, then it will register. otherwise if it passes around the beam of light, the sensor thinks your carpet is clean.
The opposite sometimes will happen too where it will stay constant red. That means that the sensor is completely covered in dirt and will not register anymore.
Hope this helps.
Mark
Nov 11, 2010 | Hoover UH70015 Bagless Upright Cyclonic...
Both the E and A strings of my Washburn acoustic guitar "BUZZ" even when lightly strummed. The guitar has "light" (.012 - .053) Phosphor Bronze strings.
Buzz usually translates to either inadequate fret clearance or poor quality strings or inadequate pressure holding strings against the fret.
The guitar DESERVES using high quality strings and I would look at the manufacturers recommended string weight or your music store should know what to use. The LIGHT strings MAY be your problem.
Nov 03, 2009 | Washburn D10sbc Acoustic Guitar
Ticking noise, not working
2 things are the bulbs good? if yes disassemble the light and remove ballast look at power loads and find equal on at home depot Loews or light store
Jul 14, 2009 | Hydrofarm 2 Ft Green Thumb Grow Light...
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
Feb 26, 2009 | Washburn X10 Electric Guitar
Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2 Logo
78 people viewed this question
Top Hydrofarm Garden Experts
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Angelo Monroe
Angelo Monroe
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
