Question about Plumbing
My 87 cierra just shut off on me. when i try to restart it will start then die again. i strongly suspect fuel injector? im not an expert though. it just seems as if its out of gas,its not. any ideas?
  • 53 Answers
Your probably not getting any gas to your engine.. may have a bad fuel pump. one way to test the fuel pump. is to spray some starting fluid down the throttle body and see if it tries to start.. if it does then you most likely have a bad fuel pump..
Posted on Mar 23, 2011
Have a dodge ram 50 pickup.. Hard to start.. Once started it will idle... Try to pull out and it hesitates and wants to die.. Back off on the gas and sometimes it will idle or dies..
Dodge Ram 50 Pickup Questions - Page 5 - CarGurus
www.cargurus.com > Questions > Dodge
CarGurusGet fast answers to your Dodge Ram 50 Pickup questions from experts in the ... 1986 Dodge Pick Up 5.9 Wont Start I Put New Distributor Set The Timing, New.
Dodge Ram 50 Pickup Questions - Carburetor - CarGurus
www.cargurus.com > Questions > Dodge > Ram 50 Pickup
CarGurusCarburetor - I recently bought a 1989 2.6L Ram50 for my son. ... Asked by redoverfarm Apr 13, 2010 at 03:36 PM about the 1989 Dodge Ram 50 Pickup ... check your fuel injector...may be clogged dirty, get a fuel injector cleaner or carburator ... Also gets poor gas mileage and is hard to start when the engine is warm !
Dodge Ram 50 Pickup Questions - 87 d 50 2.0 runs ok ...
89 Ram50 wont start.. - DodgeTalk : Dodge Car Forums, Dodge Truck ...
www.dodgetalk.com > ... > Dodge Ram Truck 1st Gen (88 - 93) Forum
Sep 22, 2011 - Hey guys i got a 1989 Ram 50 and im hoping i can get some help here. She drives like a champ but she only starts when i push start it, once i ...
Dec 26, 2015 | Dodge Cars & Trucks
87 harley fxlr w/racing cam.It starts and idles 20-30 sec.Then dies.It will not restart unless I turn the key off and on. I trouble shot all the fuel issues.Could it be a sensor shutting it down?
Hi Jeff, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable, especially the "NEGATIVE" cable where it bolts to the frame.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve, vacuum line broken or carburetor vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. A failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.
Jul 27, 2015 | Harley Davidson Motorcycles
S10 fuel injectors
Try a strong solution of Sta-bil that is a brand name sludge and varnish remover, Mix a strong mix up in the tank. Crank engine and see if it will start. If not, crank several times for about 10 seconds. Let sit overnight and try again. It seems as though your injectors are plugged. So try this. It is an awesome product.
Apr 20, 2014 | Chevrolet Blazer Cars & Trucks
My car will run fine then jus out the blue it will die and wont start back,spray eather and it wants to start on the ether.if i let it sit it will start back up,stay running fine for like three weeks...
have you put injector cleaner inside the gasoline which cleans the fuel injectors because if you use 87 octane would make the fuel injectors dirty and not allow the fuel to go into piston chambers properly so try this first. Yes the fuel pumps does mechanically go bad and plus the fuel filter goes bad because the lower octane 87 has elements that will cling to the fuel filter and clog it up so no more fuel can go to the engine so you can test them out but make sure that when you do this that you do not cause any spark by the gasoline lines when taken it out. If you do this to make sure FIRST that the Negative battery cable is off the battery terminal which is also connected to the fuel pump so the pump does not come on on accidently while your working. You can check the fuel pump too but make sure the Negative battery cable is off the battery cable before you mess with the fuel pump but also make sure when you try to take off the fuel pump and the hoses that you do not make any type of electrical spark around the fumes if you do this job !!
Jun 06, 2011 | 1997 Oldsmobile 88
Car sometimes starts hard like 1 out of every 5 starts and runs rough most times may even die out acts like a miss dies every time it is put in gear unless u foot brake it every so often you start it and...
try putting some injector cleaner into the gasoline tank because sometimes your fuel injectors do get clogged up and needs to be cleaned to allow the lower 87 octane through the injectors. Some of the times that the timing belt has been changed and misses with the timing with the piston heads and valves which opens and shuts while the gasoline fuel is being put into the piston heads chambers so if your timing is off would cause this similar problem as well.
Jun 04, 2011 | Chevrolet Caprice Cars & Trucks
I changed the fuel pump and fuel filter, im getting gas upto the injectors/carb, but only starts if i put gas in the carb, but then dies quickly wont get gas. any ideas?
If the tps (throttle position sensor) gives a high signal it will put the computer in clear flood mode which shuts off the fuel injector. Easy test, unplug the tps and try to start it. The tps is the 3 wire sensor at the end of the throttle plate If not suspect the ignition module under the distributor cap.
Feb 15, 2011 | 1994 Chevrolet C/K 2500
89 chevy celebrity 2.5 fourtech and it will start up strong for like 2 or 3 seconds then die. its not outta fuel or it wouldnt hit every time like it does and then die. we had to peel the column because...
Check fuel filter, gummed up carb. (I think that car still had a carb, if injectors, same issue, injectors could be all gummed up from old gas.)
What can happen, is fuel system can deliver or allow enough fuel to accumulate to start up the car, but it can't sustain the fuel delivery to keep the engine running.
Jun 25, 2009 | 1989 Chevrolet Celebrity
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
