Question about Maytag Atlantis MAV6451 Top Load Washer
Washer comes on but does not fill with water - Maytag Atlantis MAV6451 Top Load Washer
    Champion:
  • 239 Answers
Your pressure switch is bad. Th eserial number will dictate which one you need. Look at serial number before ordering switch!
Kelly
Posted on Mar 23, 2011
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Washing Machines
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Water comes out wash cycle good but slow at rinse cycle
do you mean filling the washer up or draining it out?i think you mean filling it up,on washers just the cold water is used to fill the washer on the rinse cycle,you can shut the water down and remove the cold water line and see if you can clean out the screen in the washer water valve,also while you have the hose off,stick it in the washer and open the valve to see how the pressure is,if it's coming out strong then the problem is in the washer and you should change the washer water valve,if it's coming out slowly then you have a problwm with the house water valve and need to change that out.let me know what you find
Aug 29, 2010 | Whirlpool LTE5243D Top Load Stacked...
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not fill in auto can force it to fill why
MAKE SURE YOUR WATER LEVEL HOSE HAS NOT COME LOOSE(ON TUB,AND INSIDE TOP HEAD)IF THATS GOOD THEN YOUR WATER LEVEL SWITCH IS BAD,LET ME KNOW-MIKE
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't fill
First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
Dec 22, 2008 | Maytag HAV3460AWW Top Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Fills with water
replace the water fill valve assy not hard at all
May 24, 2008 | Whirlpool GHW9250M Front Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
