Question about Atari Dragonshard for Windows
I'm using windows 7 32-bit. When I try to install dragonshard from autorun or setup.exe nothing shows up. I've tried compatibility mode, but nothing works.
    Master:
  • 525 Answers
If it is an older title it may have compatibility issues with windows 7. For example I have Diablo II for pc and i simply cannot run it in windows 7 because of compatibility issues.
Posted on Mar 23, 2011
Adobe Photo Deluxe 2.0 and windows 7 (x64) Adobe Photo Deluxe 2.0 and windows 7 (x64) Hi everybody. I am trying to install Adobe Photo Deluxe 2.0 on Windows 7 (x64) but I am not able. I tried to follow...
I do not believe this is possible. Adobe now makes 64 bit only programs since coming out with Creative Suite 4 and Photoshop. If you have 7 Professional or better, you can download Microsoft Virtual Machine and Virtual XP SP3 machine free (Microsoft.com) and install Photo Deluxe in the virtual machine.
VirtualBox is another free one.
Sep 23, 2011 | Acer Computers & Internet
I purchased Egames Lexicon. When I try to install it a message appears that says it cannot start or run due to incompatibility with 64-bit version of Windows. How can I get this software to work on my...
Right click on the executable file that starts the setup, typically setup.exe. Select Properties. Under Compatibility, set it to Windows XP SP3. If that doesn't work, it really won't work without you setting up a virtual machine and installing a copy of XP. If you're running Windows 7, you can download a Windows XP virtual machine to run. It's called XP Mode. Instructions can be found by searching for XP Mode in the Start menu's Help and Support.
Jul 06, 2011 | E-Games Lexicon Word Challenge for Windows
I have Windows 7 on my laptop and my cd that came with my computer does not support Windows 7 for my printer.
It might be that the printer is not compatible with Windows 7. However Windows 7 has a compatibility Mode Feature
To Do This follow the steps at the bottom
1. Insert the Printer Disc
2. Click Start > Click Computer > Right Click on the Printer CD > Click Open/Explore
3. Right Click on Autorun.exe or Setup.exe and Click on Properties
4. On the Properties Window > Click on Compatibility Tab >Put a tick on the box that says Run this program in compatibility mode for:> Select the Operating System that printer is mostly compatible for>
Click on Apply> Click OK....Double Click on Setup or Autorun it should work or you may download the drivers or patch from the HP website
Thanks for Choosing Fixya
Jun 05, 2011 | HP Office Equipment & Supplies
I am trying to install Empire Earth 3 Cd to my pc which uses windows 7. When i insert the cd into the CD-ROM the system starts automatically but is asking for password. The ok button is grayed out and i...
You are using Windows 7.
Do not execute from autorun. Right click on the CD, then chose Explore ==> find "setup.exe" then right click on it ==> go to proprieties ==>then select compatibility mode for windows xp service pack 3 or xp only, then you should be able to select run as administrator. Close the windows and double click on "setup.exe"
Let me know how it goes.
Jun 04, 2011 | Computers & Internet
HP Photosmart M420 will not install on Windows 7 laptop - stops during install and says that setup.exe is not compatible with 7 - wne to HP website and there is no driver for 7 (64 & 32 bit) - states...
https://www.pcworld.com/article/255507/run_xp_software_in_windows_7.html
Try running it in XP Compatibility Mode:
  • Right click the setup.exe file or the shortcut and select Properties.
  • Click the Compatibility tab.
  • Check Run this program in compatibility mode for and select an appropriate option.
Dec 26, 2017 | HP Photosmart M420 Digital Camera
Software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
I am unable to install hunting unlimited 4.Is it vista compatable?
It seems that Hunting unlimited 4 is only for systems up to Windows XP....
Try installing the game in compatability mode...might work...
explore the game cd
look for the setup.exe or install.exe
right click and view properties
look for the compatability tab
under compatability click the box that says run this program in compatability mode ....make sure you choose windows xp then ok the window
now double click on the exe file that you´ve just changed and see if that works
Nov 26, 2008 | Computers & Internet
Running 16 bit program on 32 bit windows xp
  1. Find the .exe for the application.
  2. RIGHT click on the .exe file.
  3. Choose Properties and then click on the Compatibility tab.
  4. Check the box that says "Run this program in compatibility mode for:"
  5. Now choose the operating system you need to emulate. (windows 95)
Nov 02, 2008 | Computers & Internet
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Atari Dragonshard for Windows Logo
375 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
