Question about Pioneer PRO-150FD 60 in. HDTV-Ready Plasma TV
Does not turn on with picture. when you first plug in one can hear a relay engage...that's it, no picture or blue light power on indicator. tried the button on the right side of tv, no go. pulled plug and waited for a few minutes, no go.
  • 643 Answers
Leave unpluged longer. Capacitors bleed of very slow. atleast a couple hours. if that doesnt help tv may have bad powersupply.
Posted on Mar 23, 2011
Standby light is light red when the power button is pressed. The power light turns blue and flashes 7 times on the seventh time stays solid blue. The panel doesn't light up or anything. I can hear the...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 16, 2015 | Televison & Video
AC compressor always engaged.
disconnect the wire at the compressor to check that the clutch is releasing,then with a test light check to see if power is present when it is switched on and no power when off.
Aug 09, 2014 | 2004 Pontiac Grand Am GT
No picture no sound, red light on, left unplugged over-nite, no change. Turn on/off a number of times, got back perfect picture/sound. Turn off, same problem, no picture/sound, red light on. Tried...
First if the model number is right here: When the red light is on about 80% of the set inside is powered up and running all out.
On these sets if you turn it off and the red light does not go out one of the relays on the power board is engaged or stuck in the closed position.
If I remember this model it has three black rectangular plastic relays on the power supply board(follow power cord into the set to see if this is the case.)
Relays have voltage and type marked on top (like 12 vdc etc).
Carefully with back removed what I would do is with something NOT metal tap on each relay until (with set turned off) the red light goes out.
That is the bad relay----if set has 3 I usually replace all as only 4 solder connections each and they are not real expensive.
I saw one of these sets where the customer had been gone for a month and when she returned set appeared to be off but Red light for power was on.
The set was so hot I tapped on the relays and then when I knew which was bad shut the set off and unplugged it to let it cool off.
I am saying if you leave the set plugged in and the red light is on There is the chance it may overheat to the point where you could have a fire.
Let me know if you have questions.
SD TECH
Sep 26, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I need a fuse box diagram for my 95 dodge dakota
Fuse 1: 30A, Green; A/C Heater Motor Fuse 2: 30A Silver (Circuit Breaker); Power Windows Fuse 3: 15A Light Blue; Overhead Consule, Day/Night Mirror, Reverse Lamps Fuse 4: 5A Tan; ABS (There is not on in the picture) Fuse 5: 20A Yellow; Power Door Locks Fuse 6: 20A Yellow; Horn Relay, Instrument Cluster, Radio Choke Relay (on Premium audio system) Fuse 7: 10A Red; Buzzer Module, Stop Lamps Fuse 8: 20A Yellow; Headlamp Switch Fuse 9: 15A Light Blue; Cigar Lighter Fuse 10: 20A Yellow; Windshield Wiper Fuse 11: 20A Yellow; Turn Signal Fuse 12: 10A Red; Radio Fuse 13: 4A Pink; Recives power from Fuse 8 to power instrument lights (such as the cigar ligher lighting, ash tray light, dash lights, radio lights, etc.) Fuse 14: 15A Light Blue; Instrument Cluster Fuse 15: EMPTY Fuse 16: 5A Tan; Buzzer Module, 4WD Indicator Lamp, Tranny O/D Switch, Tranny Oil Temperature Sensor Fuse 17: EMPTY Fuse 18: EMPTY Fuse 19: EMPTY Fuse 20: 25A Natural; Park Lamp Relay, Off Road Lamp Switch (There is not one in the picture, I believe this is only on vehicles with fog lamps)
NOTE 1: Fuse 3 and Fuse 14 provide power for the Airbag Control Module Cavities 2, and 1, respectivly. NOTE 2: Fuse 4, Fuse 7 and Fuse 11 provide power for the Controller ABS Brake Cavities 7 and 12, 9, and 3, respectivly.
Under Fuse 4, 8, and 12 is the Buzzer Module (Black rectangle in the picture) Under Fuse 16 is the Hazard Flasher (Silver circle in the picture) Under Fuse 20 is the Horn Relay (White plastic looking in the picture) To the side of Fuse 17 and 18 is the ABS Warning Lamp Relay (Open cavity in the picture) To the side of Fuse 19 and 20 is the Turn Signal Flasher (Blue circle in the picture) Between the Turn Signal Flasher and the Horn Relay is the Time Delay Relaly (the other Silver Circle in the corner, in the picture
Dec 16, 2009 | 1995 Dodge Dakota
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Pioneer PRO-150FD 60 in. HDTV-Ready Plasma TV Logo
205 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
