Question about Creative Technology Creative Inspire T3130 Speakers 21 Channel Magneticallyshielded Satellite speakers 5W RMS x 2
My speakers just suddenly stopped working its like theres no more power going through it, I've tried unplugging it and it still won't work. What should I do?
  • Creative Tec... Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 23, 2011
Logitech speakers suddenly stopped working
try first unplugging the speakers overnight then if they sitill dont work try cleaning off connectors i know this is really basic stuff but sometimes it works
May 21, 2012 | Logitech Z506 Surround Sound Speakers
Harman Kardon SoundSticks II Computer Speakers
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Won't connect to my computer. I've had the printer for about 3 years, and all of a sudden it stopped connecting and i can't get it to connect again.
check printer connections and try again but if still not working go to control panel add and remove click to select program remove HP Photosmart then back to main window, insert the disk and install again driver, follow commands you see on the screen . but first unplug internet connection then exit anti virus before you start installing driver HP Photosmart .good luck
Jul 10, 2011 | HP Photosmart C6280 Printer
My amp suddenly stopped working. Orion-Cobalt 800.1 RCA Problems.
Hello icpdownie,
A grounded or shorted RCA cable could be the problem. Try replacing the RCA's.
Hope this helps.
Aug 12, 2009 | Car Audio & Video
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
Logitech Z-10 speakers stopped working, no power
I experienced the same problem, where the symptom was initially that the volume setting was misbehaving in that you would press the to increase the volume and it would go to the maximum, and likewise press the down button and it would go to the minimum volume.  Then the screen appeared incomplete and finally it did not power on when pressing the power button.  The solution I found was to unplug the power (overnight in my case) to allow any power to drain from the unit and transformers, and then plug it back in.  It powered on afterward.
Feb 09, 2009 | Logitech Z-10 Computer Speakers
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Z10 USB connection does not work
My symptoms were that the speakers stopped working all of a sudden. Display showed power but gave no access to volume adjustment and did not play sounds.
I read a vague comment by another poster and it worked!
They said to unplug it from the power plug and leave it overnight before replugging it in...... at first I dismissed this, and tried everything else to no resolution. I was ready to return the speakers but decided to unplug it and see... Bingo********! in the morning
Z-10 is now back in action.
Oct 26, 2007 | Logitech Z-10 Computer Speakers
Open Questions:
Creative Technology Creative Inspire T3130 Speakers 21 Channel Magneticallyshielded Satellite speakers 5W RMS x 2 Logo
254 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
aliasger yq
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
