Question about Dualit 20247 2-Slice Toaster
Center element has gone? how do i fix it or are there any repaires that i could take it to in Manchester area?
  • Keith171 Apr 12, 2009
    Center element has stopped working, so only one side of the bread is getting toasted. Can you please help!
Dualit Service Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
info@electra-craft.com
www.electra-craft.com
Posted on Aug 20, 2008
I need an igniter for the burners seaward model 3372. Seaward no longer makes the stoves, so calling them yielded nothing.
took me 50 seconds to find one, GAS LIGHTER Manufacturer Part 73956
your owner manual,
http://www.marlow-hunter.com/export/Vendor-Manuals/Seaward%20Princess%20Stove.pdf
Whale Seaward Head Office
91 Manchester Valley Road
P.O. Box 1788
Manchester Center
VT 05255
U.S.A.
Tel: +1 802 367 1091
Fax: +1 802 367 1095
seaward@whalepumps.com
Sure Marine Service Center
5320 28th Ave NW
Seattle
WA 98107
U.S.A.
Tel: +1 800 562 7797
Fax: +1 206 784 0506 sales@suremarine.com
Apr 24, 2015 | Kitchen Ranges
Magic focus --blue and yellow sag in the upper left area of the screen
This is a problem with the convergence circuit. If you can solder, you can repair this yourself. First try and resolder the pins on the existing convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs.
Dan
Mar 22, 2008 | Hitachi 53FDX20B 53" Rear Projection...
The bake element burned out in my electric oven
element may have shorted . ck the element first and if bad replace it then reset the house fuse and retry. mm
Jul 14, 2010 | Whirlpool RBD305PD Electric Double Oven
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
Dyson 14 won't work when switched on
It will most likely be the motor after 8 years. It will cost you £65 for a brand new motor and a full service if you can get it over to Manchester. Try here: Manchester Dyson Specialists
Apr 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a westbend 3 in 1 Coffee Center Model 55129 and the expresso side has decided to pack up (will not heat up) the light switch works and the auto cut out works but it seems as if the boiler element...
Sadly most of these units are not repairable heating elements are spot welded to the tank at the factory . not really cost effective for the company to fix .
Nov 23, 2017 | Coffee Makers & Espresso Machines
Will not play games... doesn't spin disks
Your lense element has probably gone. You'll either have to replace it yourself or get Sony to repair it for you.
Regards
Chris
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
I believe the heating element has given it up and I need to know if there is an authorized repair center in Amarillo, TX.
Look on the web, chris322. if you don't find a repair center for Breville in your area, try other main brands like saeco, et al. they may laugh & tell you to buy a better machine; at the very least expect to spend a bit to fix it. don't rule out the possibility of a bad knob or loose wire, though. i suggest checking out ebay or craigslist. starbucks barista machines usually go for $200-$250, and if you buy one used face-to-face and it's working, it will most likely continue working for long while. try finding a heating element to replace it, and call around to electrical repair shops to see if they'll put in it for you. good luck to you!
Jan 07, 2009 | Breville ESP8XL Espresso Machine
New codes for eurovox for the 5C 01 provider have just gone off
5A01
B7 19 92 E2 9B 15 AF 96
3C 12 5C 17 D4 3F 7E 64 DONT KNOW THE PROVIDER NO FOR MANCHESTER
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Dualit 20247 2-Slice Toaster Logo
337 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
