How do you configure scan for TAB KEY & enter?
  • 368 Answers
Glad to HELP YOU!
It's pretty easy! Just follow these steps:
1. right click on the SCANNER icon in ALL PROGRAMS
2. select PROPERTIES
3. click on PROPERTIES and you will see the input field called SHORTCUT KEY
4. hold down the TAB and ENTER keys you want to assign
5. click on OK button
It's done! Now you can start the scanning operation just by pressing the same time TAB and ENTER keys.
My best wishes!
Posted on Mar 23, 2011
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
I have an AS-8150 Argox Scanner. How do I configure for Suffix tab to enable it tab after every scan?
how can I configura my AS8150 bar code scanner to scan and Tab instead of the present scan and Enter
Sep 23, 2010 | Computers & Internet
How to chek which vga card is builtin in mother board gx 270
Visit the link given below.
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&cs=19&l=en&s=dhs&~tab=2
Solution 1= Goto tab current system configuration and scan your computer configuration
Solution 2 = Enter service tag and click continue, factory loaded configuration list will appear.
May 29, 2010 | Dell OPTIPLEX GX270 (Y1057) Motherboard
How do I find or change my wep key? Belkin router
For this first of all u need to know the ip address of the wireless router.and its username & password.. Once u know the all this u will enter the wireless router configuration wizard.. In it go to security tab , there u can see security type and then change its wep key
May 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
{TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Mar 03, 2010 | Symbol LS2208 Handheld
I'm trying to get an internet connection on my laptop (Professional 2000) at a temporary location. I've gone through the steps of the wireless network wizard to get the wireless settings )SSIS, network...
Hi, Follow the steps below to configure the below settings:
1. Double click on MA111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.x.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 30, 2009 | NetGear MA111 802.11b Wireless Adapter
I need settin my modem to my pc netgear wg311
to configure the WG311 on the computer, first instll the adapter using the driver CD. follow the step below to configure wireless connection:
1. Double click on WG311 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
7. Apply Settings .
10. If you are getting an IP address in the format of 192.168.1.x, try to go online.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 05, 2009 | NetGear WG311 54 Mbps 802.11g Wireless PCI...
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
