Question about Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2
I have a Hydrofarm Green Thumb Light System that has an opening 30" high by 48" wide. I do not understand how to set up the string to adjust the height of the lamp. This was a gift of a used system without a manual.
I have a set of 11-48 12string i have never strung a 12string guitar before.can you tell me what string goes in what hole? 48 40 30 26 20 16 14 14 12 11 11 9
the Heaviest string of each string pair is placed at the top (closest to your nose). In fact, if you look at the nut, (the notched thingy that spaces and holds the strings at the right spacing up by the tuning pegs) the notches in nut are wider than the paired string for this reason. That may not be true on all 12 strings but it is on mine. So the typical arrangement is heavy string, matching string. Heavy String, matching string. Except on the bottom 3 pairs where the actual string thickness can be the same. One caution note here....when tuning a 12 string, tune it a whole step lower. So rather than tuning it at EADGBE, tune it at DGCFAD then use a capo on the 2nd fret to bring the tuning up to EADGBE.
The reason for tuning a whole step lower is because on the top 3 pairs of strings you normally tune the thinner string an octave higher to give that 12 string sound. So if you start tuning at EADGBE, those thinner strings for the top EAD strings are going to be pretty tight and they will snap. So much safer to tune a whole step lower and just use a capo!!! Good Luck
Nov 13, 2017 | Music
Xantrax xw6048 with 30 each 235w orion poly solar panels.company rep. stresses that it should be connected no more than 3 sets each.What does this mean?I was thinking of 3 strings of 10 panels.
Yes. That's what that means. 3 strings of series wired panels. Now, the panels are going to be around 30 volts (vmp), so it all depends on the input voltage of that unit. I'd check the voltage range of the charge controller. If it's limited to lets say, 192 volts max for a 48 volt system, you can do 3 strings of 6 panels to keep it under the voltage.This will give you a 4230W panel output every hour, which is substantial.
Oct 18, 2013 | Xantrex Technology Electronics - Others
12/24/2012: XBOX 360/RB3-WIRELESS FENDER MUSTANG PRO-GUITAR: WON'T PLAY "FRET NOTES"
If your guitar was not purchased new (since it was hard to find these guitars late in the life cycle) then perhaps it was already faulty before you received it.
Dec 25, 2012 | Mad Catz Rock Band 3 Wireless Fender...
Cant get the buzz out of the high E string on my Epiphone les paul guitar
A buzz on one string is not due to a pickup fault. It's rather a too low string height at the nut or a string slot that is either too wide or has too deep of an angle towards the tuner. It could however be that you had the pickup too close to the high E string creating excessive string pull.
Jul 04, 2012 | Epiphone Les Paul Studio Electric Guitar
Cant figure it out, has 4 black segments that each represent 15 minutes, and i still dont understand how to set it for 16 hours on, and 8 off...
Dial has 48 segments.
Each segment represents 1/2 hour in 24 hour day.
Pull up 32 segments and leave 16 segments down.
Manually rotate dial and watch when light turns on-off.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 09, 2011 | Hydrofarm Timer 24 Hour
I have a hydrofarm 24 hour dual outlet timer, analog, with 4 black segments, each representing 15 minutes,. I have read the directions over, and over and still dont know how to use the darn thing... i just...
Add a comment and post a photo of your timer so we can have close look at your do-it-yourself problem:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Ticking noise, not working
2 things are the bulbs good? if yes disassemble the light and remove ballast look at power loads and find equal on at home depot Loews or light store
Jul 14, 2009 | Hydrofarm 2 Ft Green Thumb Grow Light...
Connect ballast to light
black to black and white to white, the green wire is the ground. the lighter colored wire is most likely for european connection if it is a switchable ballast.
Jan 27, 2009 | Hydrofarm Flco95w Grow Light System
Hydrofarm 2 Ft Green Thumb Grow Light System Model Gtv2 Logo
76 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
