Question about LG Televison & Video
Has a region lock on my LG RH397D player - LG Televison & Video
  • terridale Aug 07, 2008
    Thanks for your responce to my e-mail and i tryed what you sugested but it did'nt work.
    I only just got the dvd player and i could'nt play dvd's that were region 1 movies that i got from the U.S.
    Thanks for your fast responce.
    Terri.
  • L Jefferson
    L Jefferson May 11, 2010
    If you want you can try this but i can't garrentee it'll work as its for another LG R
  • Power On
  • Open tray
  • Press 0 button 7 times H model.
Just tried the hack posted on VideoHelp on my 397D player and it worked straight off:
1. press home on remote
2. scroll to setup options
3. scroll to lock (DO NOT SCROLL SIDEWAYS)
4. press zero seven times (message appears)
5. press enter
Posted on Jan 12, 2009
  • 376 Answers
Here is the official software from LG to unlock region codes on all RH 3xx series HDD players.
1. Go to http://hk.lge.com/support/support_lgeservice.jsp
2. Go to "Product Support"
3. On the left panel, find "Device Drive", then "DVD Player/Recorder".
4. Download the "RH3xx.iso" from the linked page.
5. Burnt ISO to a CD (must be burnt as an image, use free software such as ImgBurn http://www.imgburn.com/)
6. Load CD onto the LG player
7. You will be prompted to choose a new region code - go with 0 for region-free
I think this will be the last option to unlock this player. Hope this finally solves your region problem.
Posted on Aug 16, 2008
3 Suggested Answers
SOURCE: has a region lock on
5. press enter
dvd player now region free
Posted on Apr 01, 2009
SOURCE: How do I unlock my LG RH397D DVD player to play
http://hk.lgservice.com/gcsc/b2c/hpi/main
download file
burn to cd
put cd in player
change region code to 0
Posted on Dec 04, 2009
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
Can't play USB MP4 on LG RH397D
The LG RH397D only supports MP3/WMA/JPEG/DivX image and audio files from a USB drive. There is no firmware update that changes the supported file types. You will need to convert the MP4 to a supported format. The manual for the RH397D is available from LG: http://www.lg.com/au/support-product/lg-RH397D# /
I wish that I had better news for you.
Aug 06, 2012 | LG RH397H DVD Recorder
My LG RH397D HDD wont recognise dvds any more
The only thing you can do is try a DVD cleaning kit and follow instructions, if that fails the laser pickup assembly will need to be replaced, but this would be to expensive and far cheaper to replace the player.
Mar 27, 2012 | LG Televison & Video
What do I do to make my LG RH397D regeion free?
Try the following method.
Using the factory supplied remote:
1. Press 'home' button
2. Scroll to 'setup options'
3. Scroll to 'lock' (don't scroll sideways)
4. Press the following button sequence: 0, 0, 0, 0, 0, 0, 0 (message appears)
5. Press 'enter'
When attempting to play other region discs, it may take a few seconds for the firmware to recognize the disc.
Hope this helps...
Aug 28, 2011 | LG Televison & Video
I have an LG RH 398 H DVD recordable player - bought in Canada I want a chip code to change it to a mutli region. Can you help ? Thanks
These are the remote codes for an LG RH397D, maybe it will be the same for your 398H.
5. press enter
I hope that helps.
Jan 15, 2010 | Televison & Video
How do I unlock my LG RH397D DVD player to play all regions?
download file
burn to cd
put cd in player
Oct 03, 2009 | Televison & Video
I need to unlock the regional code on my DVD player
The code I found from a trusted website says:
  1. Press SETUP
  2. Scroll down to the padlock icon
  3. Press 0 seven times
    • Confirmation message appears
  4. Press ENTER
Which sounds like what you're doing already. This is for RH399D. RH397D may be different.
Apr 13, 2009 | Televison & Video
Region problem with LG DVD RH265
no problem! I just bought a LG RH265 and made it multi region with no problems:
on your remote-
1) press HOME
2) move to SET UP
3) scroll down to LOCK (no need to enter LOCK options)
4) press "0" seven times
5) a message will appear stating the dvd player is region free.
6) ENJOY!!!
Dec 10, 2008 | LG LST-3510A DVD Player/Receiver
Has a region lock on my LG RH397D player has a region lock on problem With my LG RH 2T80
5. press enter
Oct 03, 2008 | Televison & Video
I would like an region unlock code for an LG RH397D DVD player thank you kathy
Hi, try this, works for me
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Hope it helps you too. Ashley
Jul 24, 2008 | Televison & Video
Televison & Video Logo
1,200 people viewed this question
Computer Repairing
Computer Repairing
