Question about Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
If prompted, enter 0000 for the PIN code/passkey.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Good luck from Headsets Direct!
Posted on Oct 24, 2011
Bluetooth set up for playstation
1. Turn headset on
2.Go to Accessory Settings then Register bluetooth device
3. Go to register Headset
4.Follow setup instructions
5.when your device is discovered enter passcode which is usually 0000
6. Try putting your finger over mic if headset cant be found...thats what i did with mine
May 22, 2011 | Sony Playstation 3 (PS3) Console
Okay i have the mad catz 8806 mic it flashes red and blue and charges fine but i cant talk into it and cant hear anyone through it at all it beeps and i hear that.
If the headset you have is the Item No. 8860 in order to use it you have to pair it.
If you are using it on a PS3 then be sure that you have selected the headset in the PlayStation's settings.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Troubleshooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Hope it helps
Apr 06, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you pair wireless headset with ps3?
On the PS3, navigate to Accessory Settings > Manage Bluetooth Devices. At the bottom, you'll then select Register New Device. Then place your bluetooth headset in pairing mode, usually by holding the power button until the LED blinks rapidly. Back on the PS3, then select Start Scanning and select your device. The PIN for all headsets by default is 0000.
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Trouble Shooting
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Ps3 at v3.15, sony headset paired but cannot get speaker on tv
Go to the Audio Settings above the Bluetooth setting and change the Audio output to "wireless headset"...
Jan 10, 2010 | Sony Bluetooth Wireless Headset for...
Connecting bluettoth to playstation 3
there are two different places in XMB to change your headset settings. If both of these are not active then it will not work. One is accessory settings Manage bluetooth devices and make sure the headset has a blue dot by it, the other is accessory settings also and audio device settings. Make sure the input and output device settings are set to the headset
Jan 10, 2010 | Video Game Consoles & Games
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
Using PS3 Sony Wireless Headset with EndWar game
Go to "settings" on your XMB (cross media bar) scroll down to "Accessory Settings" then scroll down to "Audio Device Settings" and make sure your "Input/Output Device" is using "Wireless Headset".
Apr 26, 2009 | Ubi Soft Video Game Consoles & Games
Hooking my headset up to my playstation 3..
go to your phone's bluetooth menu and then find the headsets profile in the my devices menu and then delete that profile
Jun 03, 2008 | Plantronics Explorer 320 Wireless Headset
Turning on headset freezes wireless controller at times
one of the best wireless headsets on market is a jabra.its the one they sell with warhawk for £40. otherwise you can pick one up for around £20....
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset Logo
345 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
