Question about HP LaserJet 4 plus Printer
HP 1018 PRINTER
MY PRINTER PROBLEMS ARE:
1. PRINTIING IS INEQUAL GAPS
2. AT 3/4 OF PAGE IS FOLDED
3. PAPER IS NOT COMPLETLY NOT COMMIN OUT, 10% OF THE PAPER STRUCKS AT THE OUTPUT PAPER SENSOR.
    Master:
    Sergeant:
  • 398 Answers
This is a great old printer, and it sounds like you have paper feed problems. Firstly I suggest you go to ebay, and find one of the repair manual CDs for hp printers. They are very cheap and cover all of those older printers. Then Google for: exit feed roller assembly for your machine. They are really easy to install when you have the cd, it shows you exactly which clips and screws to take out and how to remover and replace the assembly. There is also a great trouble shooting section, I have three of these old machines and they are just great, and comparatively easy to maintain with these repair maual cds.
Posted on Aug 03, 2008
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
My HP Office Jet won't print the entire document sent to it when it is asked to print double sided. And repeatedly will fail at the exact same spot in each document; although the spot where it fails is...
There are 3 step to repair 1018 error
If you got 1018 error then there is a 94% chance that your computer has registry problems. To repair 1018 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 1018 error.
Here are the url of Perfect Optimizer:http://www.pcerrorremover.com/tidpp-1018...
Jul 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My Ricoh Aficio printer 1018 is telling me to "load paper 8 1/2 * 11" on the screen whenever i try to print anything from any computer in the network because i am using RJ 45 instead of normal...
Make sure you have 8.5" x 11" paper loaded into at least one of the paper trays, and make sure it's loaded in the same orientation as the page you are trying to print. Also check to be sure the copier is set to recognize 8.5" x 11" paper -- it may be set for a different size. On the main Copy screen, if you select the paper tray, does it show 8.5" x 11"?
Feb 03, 2011 | Ricoh Aficio 1018 Printer
I have a problem with my printer hp 1018 only print white pages please help me
I seems like you have snaped the pin is broke. if you open the printer on the right hand side there is a little hole with leaver in shove some folded paper in it and close top. the leaver has to be pushed down for the printer to work. if the leaver is not down it will print blank pages.
Sep 24, 2010 | Office Equipment & Supplies
Remove jamm paper from the hp laserjet 1018
bring out your catridge and try to pull out the paper out of the printer, lastly use forceps for the resedual paper stuck into the paper roller
Apr 13, 2010 | HP LaserJet 1018 Printer
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
Hp4650 printing BLANK pages
Try printing a configuration page to see if that comes out. If it does then you might have a print driver problem. Also try printiing a test page from the printer properties on that printer.
Mar 30, 2009 | HP LaserJet 4650 Color Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
HP LaserJet 4 plus Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
