Question about Welding Tools
How to set up lincon mig welder - Welding Tools
  • 407 Answers
Hi:
In order to help you better, Please specify model.
Posted on Mar 23, 2011
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
I have a fuel prob.in a lincon 300 g starts for a couple seconds then fuel stops going into carb and dies, could it be the fuel pump?
If the unit sat for a while the jet in the carb is clogged,if this is the case the carb must be removed and dissasembled,the jet has a small orifice that can be cleanened with a paper lip or a torch cleaning wire.
Feb 26, 2011 | Lincoln Ranger 305g Welder Generator...
Lincon mig 100 need wire feed wheeh for solid & flux core
solid wire drive rolls are not the same as flux core. Solid are U-grooved while flux cores are knurled. Any welding store can get it for you. Perhaps you can find one that has twin groove.
Nov 05, 2010 | Welding Tools
My wire feed wheel on my lincon sp130 mig welder has ceased to turn. How do I trouble shoot if it is a burned out motor or something else?
Check the voltage at the wire feed motor while the trigger is pulled. If there's no voltage, it's pretty safe that it's not the drive motor.
Also, with the unit unplugged, check the big power (stud) diodes for shorts.
I had a wire feed motor stop because 2 of the big diodes were shorted.
Apr 20, 2010 | Welding Tools
I have a lincon 3200 hd. it stoped feeding the wire when i was welding. but it feeds when i pull the triger, till i try to weld again
These welders have thermal breakers in them so if they get to hott the will automatically stop feeding the wire but the fan will remain on, try changing the breaker i think its in the door where the spool is held. good luck]
Apr 13, 2010 | Welding Tools
I have a sp 100 lincon pull the trigger it clicks, no wire fd
not diode problem,check enternal wiring and relay for feed motor.
Jun 25, 2009 | Lincoln Welding Tools
Was welding 10 min later mach. quit power was good circut breaker was good and fuses were good
it probably has a fuse for overheating safety, or else the feed motor fried
Apr 24, 2009 | Welding Tools
Can you help with the settings on this mig welder
Can you explain what settings you want to know
http://www.mig-welding.co.uk would be where I'd go
Apr 16, 2009 | Welding Tools
I lost the owners manual to my lincoln weld pac#100 welder
hi mack:if you call or emal lincon customer care department theyll be happy to send you a owners manual to give you your gas shield capablitys ,thats what there there for.the customer. hope this helps jojogunne
Mar 10, 2009 | Lincoln Welding Tools
Welding Tools Logo
32 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
